Username Post: 46 Stylemaster        (Topic#346973)
46Stylemaster
Reg: 01-04-17
09-04-17 07:12 AM - Post#2706651
Anybody have :
- pic of clutch / trans linkage connections
- way to test vacuum assist?
09-04-17 08:02 PM - Post#2706715
    In response to 46Stylemaster
Do you have a service manual? It should be in there. Here is the online manual site.
http://chevy.oldcarmanualproject.com/
46Stylemaster
Reg: 01-04-17
09-05-17 05:50 AM - Post#2706722
...Looked ...but cant find a legible pic on the shift linkage
clutch pic is good...
think my vacuum unit is shot... but not dont see a test-for-dummies kinda thing!
09-05-17 09:51 AM - Post#2706734
Does this help any?
http://chevy.oldcarmanualproject.com/parts/1929_41...
Unless you are doing a stock resto for show points, you might want to consider getting rid of the vacuum assist. For many years, the aftermarket offered a kit of parts called a "vacuum shift eliminator", which converted the car to straight mechanical linkage. After installation, the trans shifted quite well. These kits still turn up occasionally on ebay.
One of the vintage specialty parts vendors has promised a revival of the kit, but it is just vaporware so far.
https://www.chevsofthe40s.com/detail/21425/Gear_Sh...
If your fab skills are up to the job, you could likely make a suitable substitute yourself.
46Stylemaster
Reg: 01-04-17
09-07-17 06:57 AM - Post#2706906
my fab skills are....missing
yeah, ebay has eliminator rod for $50...for 1939
doesnt work on 1946
09-07-17 09:59 AM - Post#2706924
Unfortunately, 1939 was a one-year-only setup because the trans changed significantly for 1940. I believe 40-48 all take the same conversion kit.
You might want to contact C of the 40s to ask when (or if) they expect to have the kit available for shipment. If I find it offered on any other vendor's site, I will post here with the info.
Execution time: 0.668 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:48 AM
