LMC Truck
Username Post: 2016 3.6 VVT engine - better than previous years?        (Topic#346966)
letsbangout
Reg: 11-29-11
09-03-17 02:38 PM - Post#2706602
So this isn't a full-size SUV question, but this sub-forum seems like as good a place as any to ask. Older 2009 to 2015 3.6 VVT engines are known for premature wear on the timing chain, and loud ticking from the high-pressure injectors. Yet most other engines with timing chains and direct injection do not suffer from these symptoms. There is a TSB on the 2015s and below. Can anyone tell me if the 2016s were improved in any way?
I was considering a 2014 Buick Enclave with this engine, but the ticking bothers me immensely, because it would tend to mask any other problems in the top-end. The Buick also vibrated much more than what I would consider normal for an engine with 26k. We looked at a 2016 Acadia that was quiet as a mouse, so I'm wondering if they made improvements over the years?
http://www.revbase.com/BBBMotor/TSb/Download Pdf?id...
LMC Trucks
letsbangout
Reg: 11-29-11
09-03-17 03:49 PM - Post#2706610
    In response to letsbangout
The more I read, the more disappointed I get. Apparently these engines, even 2016s, suffer from bad rod bushings and loose wrist pins.
https://gm.oemdtc.com/5541/ticking-tap-or-r attle-n...
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
10-07-17 01:54 PM - Post#2710072
I have NEVER heard of a direct injection engine with a quiet fuel system. They all tick. It is just the nature of the beast when you have a pump making 2,000+ PSI fuel pressure and have fuel injectors strong enough to open against the pressure. My M56S Infiniti has very noticeable ticking and even what I would describe as a clattering sound and it is 100% normal.
My sisters 2014 Silverado and her bodyfriends 2014 Sierra sound very similar.
My uncle has a new Sierra with the 6.2 and it sounds the same.
The 2017 Nissan Titan/Armada and Pathfinders all have a distinct ticking noise as well.
I have also noticed similar noise from the Hyundai/Kia engines that have DI.
Edited by 1983G20Van on 10-07-17 01:55 PM. Reason for edit: No reason given.
10-07-17 05:48 PM - Post#2710090
    In response to 1983G20Van
For what is worth my 2015 Malibu is quiet even with the hood open. More of an issue is deposit build up on the intake valves as they are no longer exposed to fuel flow.
1983G20Van
Reg: 11-13-02
10-14-17 07:43 AM - Post#2710827
That is no joke either! I pulled the intake manifold on my 2011 M56S at 90K and cleaned the intake valves and ports using crushed walnut media blasting and B12 carb cleaner. Difference was night and day. I had tried two chemical cleaners through the PCV ports before I ended up pulling the intake. It cleaned the intake ports on the front 4 cylinders and deposited all that gunk directly on top of the intake valves as a messy gooey gummy deposit.
10-14-17 10:04 AM - Post#2710839
Hell of a thing to look forward to with all the direct injection engines out there!! I did the Seafoam process through the throttle body at 15k on my Malibu, no way to ascertain the results. It has plenty of power as of now, 100k engine warranty won't cover this!
10-14-17 10:10 AM - Post#2710841
The local "car talk radio show" guys here recommend regular cleanings with the BG tool that hooks to the fuel rail. They assert that if you start it before buildup happens, and repeat it regularly, that you can keep the buildup away. Whether or not that method stands the test of time, I guess we'll see!
LMC Trucks
Execution time: 0.257 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:26 PM
