Username Post: Brake In a Box - thoughts?        (Topic#346849)
57chevypreterist
57chevypreterist
Loc: Tampa, FL
Reg: 09-29-05
08-27-17 06:05 PM - Post#2705797
Time to upgrade my stock drum system. I'm not adding power brakes and I'm not adding disc brakes.
I am adding a dual chamber master cylinder, and I am replacing the lines.
I heard about the "Brake In a Box" system and I am wondering if it is worth the price. (Musclecarbrakes.com)
Does anyone have experience with it, and feedback they are willing to provide?
Thank you all in advance.
-Bryan
1957 Bel Air four door sedan, 43,000 original miles, 235 Blue Flame Six, 3 speed, 2nd owner, acquired in 1978.
http://www.flickr.com/photos/81952637@N00/s ets/721...
Edited by 57chevypreterist on 08-29-17 04:31 PM. Reason for edit: No reason given.
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
08-28-17 09:44 PM - Post#2705974
    In response to 57chevypreterist
I've never heard of this product. A link might be helpful.
Jalapeno
57chevypreterist
57chevypreterist
Loc: Tampa, FL
Reg: 09-29-05
08-29-17 04:26 PM - Post#2706057
    In response to Jalapeno
Sorry, Jalapeno!
Here you go!
http://musclecarbrakes.com/index.html
-Bryan
Jalapeno
Jalapeno
Reg: 04-30-00
08-30-17 04:44 PM - Post#2706192
Ceramic brake shoes/pads have been around for a while and are significantly better than other materials. If the Kit you order has parts like springs, clips, adjusters, etc that are specific to your vehicle then it sounds like a good product. You can also get ceramic shoes from many sources and might be a better deal if all your other hardware is OK.
Jalapeno
zeke fishburn
Reg: 09-23-06
10-24-17 03:06 PM - Post#2711985
I've been running their complete kit with my factory drums for nearly 20 years now. I've got a 1956 210 2 door with a 235 & a 'glide. Their stuff works and John has amazing customer service skills.
The car stops well...for drums. I still run a single circuit master which, admittedly, is dumb. I've done several write ups of their products on Inliners.org, the H.A.M.B. and maybe even here.
I've got the complete trick kit including the high capacity wheel cylinders, spring kit, star adjusters and shoes.
It's as good as you're ever going to get drum brakes to work.
57chevypreterist
57chevypreterist
Loc: Tampa, FL
Reg: 09-29-05
12-29-17 04:14 PM - Post#2719362
    In response to zeke fishburn
Thank you, Zeke! I appreciate your information.
-Bryan
Execution time: 0.232 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:39 AM
