Username Post: Semi-metalic vs Stand. Brake shoes        (Topic#346833)
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
08-26-17 07:58 PM - Post#2705714
Would anyone have an idea whether or not semi-metallic brake shoes (NAPA) will affect rear drum wear on a tri5? Thanks
Stanley
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-27-17 06:13 AM - Post#2705740
    In response to 4dr 57
all brake shoes by design will cause some wear, but ID suggest the ceramic brake shoes as they leave noticeably less residual dust and seem too wear well, and not cause quite as much drum or rotor wear in my experience vs semi metallic (much cleaner with ceramic shoes)
http://www.sears.com/articles/automotive/r eplaceme...
http://www.rockauto.com/en/catalog/chevrolet, 1956,...
http://www.monroebrakes.com/catalog/e-catalog
and of course theres the option of upgrading to disc brakes
http://www.partsgeek.com/12wccyb-chevrolet-two -ten...
http://www.stoptech.com/technical-support/tec hnica...
Edited by grumpyvette on 08-27-17 06:23 AM. Reason for edit: No reason given.
4dr 57
4dr 57
Reg: 11-10-04
08-27-17 04:31 PM - Post#2705792
    In response to grumpyvette
Grumpyvette - Thanks for this batch of interest. I was surprised to learn some things that I thought turned out to be the opposite was true. In particular under Ceramic brake material i discovered that it for street use, that it produces less dust, as well as other factors.
Stanley
It's all good. mostly
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-28-17 06:24 AM - Post#2705836
glad too help when I can
rod
Loc: kingman,az
Reg: 04-29-00
09-14-17 05:33 PM - Post#2707668
I failed to see ceramic brake shoes, just std. old time shoes. did I miss something?
Rod in AZ
09-15-17 05:44 PM - Post#2707759
    In response to rod
Probably not, most of the ceramic stuff out there is disc brake pads, not drum brake shoes.
Musclecarbrakes in TX has aggressive drum brake shoes.
The wear factor is not a big deal on an enthusiast car. Brake drums and rotors are cheap compared to the benefit. And it's not that bad.
4dr 57
4dr 57
Reg: 11-10-04
09-26-17 02:13 PM - Post#2708923
    In response to Rick_L
Thanks Rick. I appreciate it.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
10-03-17 01:09 PM - Post#2709651
Yes, worry less about wear and more about stopping power. I really like name brand semi-metallics, like Wagner's MX line. And today's compounds seem to have less dust and virtually no noise. I remember the old Metal Master metallic pads from the 80s-90s (now Axxis) which worked great, but they could be noisy and weren't easy on drums and rotors.
Execution time: 0.247 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:47 PM
