Username Post: 53 PU wiring        (Topic#346743)
Mick53
"2nd Year" Platinum Supporting Member
Mick53
Loc: Northern Indiana
Reg: 04-02-16
08-21-17 07:43 PM - Post#2705153
Hi folks. I'm building a 53 pickup. It has a lot of accessories. Should I install every thing and then take it in to have it wired? This is going to be a show-n-go truck. They don't seem to make one to suit my needs.
08-22-17 08:41 AM - Post#2705191
    In response to Mick53
Are you saying that you have no intention of doing the wiring yourself?
Mick53
Mick53
Reg: 04-02-16
08-22-17 12:23 PM - Post#2705213
I could do it but I'm afraid it would not look nice.
08-22-17 05:30 PM - Post#2705246
Ok, then I would suggest American Auto Wire, who is one of our sponsors. Their harnesses are totally plug and play and will look like stock, or maybe even better than stock. Of course, it won't be cheap, but if you are paying a shop to install it, your labor cost will be lower than with "universal" harnesses which require more work.
Mick53
Mick53
Reg: 04-02-16
08-23-17 07:50 AM - Post#2705294
Thanks Ray. Do I just tell them what I need to hook up and they make it to work? Don't really care about the expense. I'm not without skills.
08-23-17 08:06 AM - Post#2705299
You need to install everything that is electrically powered so they know where to run the wires and be able to test everything.
65_Impala
Reg: 12-29-02
08-25-17 08:57 PM - Post#2705622
    In response to acardon
The AAW stock replacement harness won't be much use if your accessories are not stock. So, you pretty much have to use a universal harness to get it right. You could see if AAW has an upgrade harness for the truck. It's a universal harness with a bunch of extras tailored to the truck so it's easier and complete compared to using a simpler universal harness.
Mick53
Mick53
Reg: 04-02-16
08-26-17 07:05 PM - Post#2705706
Thanks Don, There is way too much stuff for me to be comfortable with. This truck is all in and I don't want the wiring to be sloppy.
Execution time: 0.161 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:29 PM
