40 Years of Service
Username Post: Big Brake install on a 65 Impala (updated)        (Topic#346638)
283_turbofire
283_turbofire
Loc: Bunsbeek, Belgium
Reg: 06-06-04
08-17-17 01:52 AM - Post#2704540
Hi Guys
I have a few questions regarding the install of a CPP big brake kit on a 1965 Impala.
On the proportional valve there are 3 inlets for the brake lines.
Two 3/8" inlets to the front brakes and one 9/16" to the rear.
I have 3/16" tubing for the front, which has 3/8" flare nuts so there's no issue here.
The one to the rear brakes is a 9/16" inlet and I 've found a 9/16" flare nut for that.
This nut is for a 1/4" brake line though (I didn't find any 9/16" nuts for 3/16 brake line, do they actually exist?)
My problem now:
The axle brake lines provided with the kit are 3/16 lines with 3/8 nuts.
in the rear I have a Tee (original) with 3/8" inlets (which fits the provide lines) but I don't find any 3/8 flare nuts for the 1/4 line to the front.
Can anyone point me in the correct direction on how to solve this, since I'm a bit stuck here.
Another obstacle in providing myself with serious stopping power:
the wheel lugs provided in the kit are way bigger than the original ones (picture link below)
Do I need to drill in the axle (a 10-bolt), if so, which drill do I use best?
Or did I get the wrong lugs?
Code:
 https://onedrive.live.com/embed?cid=D6B8DD8A07DE2D97&resid=D6B8DD8A07DE2D97%21429538&authkey=AMQ1wx0bzrS4kH4
Thanks a lot for the feedback
Regards,
Mark
1965 Chevrolet Impala SS 283 cui with Powerglide 17" Torq Thrusts
Edited by 283_turbofire on 08-28-17 11:18 AM. Reason for edit: No reason given.
283_turbofire
283_turbofire
Reg: 06-06-04
08-28-17 10:23 AM - Post#2705876
    In response to 283_turbofire
Ok. I figured it out myself. I just need to find a rubber brake hose with 7/16 male and 7/16 female, wich is aproxx. 16" long.
Any suggestions on who sells these?
Wonder why this hose is not provide with the kit. Since you'll need to install 1/4 brake line to the back.
Or am I completely wrong here?
Another interesting thing:
While trying to install the hubs on the original spindles, I noticed that wheel bearings (the one that goes first) do not slide on the spindles. I can't get these Chinese bearings on it.
Anyone had this problem?
I guess I have to contact CPP, since they are not watching this forum.
Grtz,
Mark
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
09-11-17 01:20 PM - Post#2707408
Mark, If you still are having issues please call me directly. I didn't get the notification of this post. My apology's! 800-522-5004 Ext 125
Thanks,
Aaron @ Classic Performance
800-522-5004
Execution time: 0.167 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:22 AM
