Username Post: Fuel pump location        (Topic#346560)
T57
T57
Loc: NE Ill.
Reg: 01-07-06
08-13-17 07:40 PM - Post#2704040
Hi folks.
I'm running a 454 with a electric fuel pump in a 57 belair.
My question is the pump placement. From what I have read it is best closer to the fuel tank instead of in the engine compartment.
I have always got great info here and was wondering what the good members here thought about this,and would welcome any thoughts.
Thanx for looking..."T"...
P.S. carbureted with 2X650 cfm
IBEW
57 belair
ski-doo
Lead sled 58
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
08-14-17 07:48 AM - Post#2704093
    In response to T57
You read it right .Try to keep it away from exhust pipes too.
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
T57
T57
Loc: NE Ill.
Reg: 01-07-06
08-14-17 03:22 PM - Post#2704167
    In response to Lead sled
Copy that! Thanx for the input!
IBEW
57 belair
ski-doo
08-14-17 05:14 PM - Post#2704205
    In response to T57
Ideally an electric fuel pump should be gravity feed. You can't do this with the OEM style fuel pickup.
Electric pumps are really bad at making suction, while mechanical pumps are very good at it.
The problem with gravity feeding an external pump is that is you must weld a fitting on the bottom of the tank, and usually that's a hazard to getting damaged.
It's best to use a mechanical pump. Holley and Edelbrock make BBC mechanical pumps that fit most BBC swaps.
Another way to do it is to use an in-tank pump, like is typical for fuel injection.
WagonCrazy
WagonCrazy
Reg: 06-07-05
08-15-17 05:53 AM - Post#2704291
    In response to Rick_L
One more thought to add to Rick L's:
If you mount an exterior electric fuel pump, make sure it's accessible for easy replacement....because they tend to burn out from the heat they generate when running all the time.
That's why its best to go to an in tank pump setup...so its submerged in the fuel thereby keeping it cooler when it's working.
And for sure, if you stick with the exterior pump plan, keep it as far away from the exhaust pipes as possible, because those just add to the heat woes which decreases the longevity of the pump.
Black57
Loc: Milwaukee, Wi.
Reg: 02-08-04
08-15-17 06:45 PM - Post#2704390
    In response to WagonCrazy
I ran a electric pump right off the connection for the fuel tank for years.
Yes electric pumps aren't great at sucking BUT they won't have a problem sucking 8 inches worth of line. It when you mount them further away when you run into problems.
Another thing, you don't need a crazy big Holley fuel pump flowing like 97 gallons a hour unless you are running a crazy souped up engine.
Basic carbed engine, maybe a bit more, this would probably work for you.
https://www.summitracing.com/parts/atx-e8012s/over view/
Remember what I said not needing a crazy high GPM flowing pump... Well what happens when a pump WANTS to pump fluid through it but can't (or should I say restricted) it strains itself, over heating or burns itself out..
T57
T57
Loc: NE Ill.
Reg: 01-07-06
08-16-17 12:52 PM - Post#2704467
Unfortunately, my block isn't set up for a mechanical pump. (marine block).
I have a good holley pump that should be enough for the 2 650 cfm carbs. It has worked set up on the side giving me the 7-9 lbs. I need.
Gonna go with this first, and then to the in-tank style if the holley dosen't cut it.
IBEW
57 belair
ski-doo
T57
T57
Loc: NE Ill.
Reg: 01-07-06
08-16-17 12:53 PM - Post#2704468
    In response to T57
I would like to say thanx for all the ideas!
..."T"...
IBEW
57 belair
ski-doo
T57
T57
Loc: NE Ill.
Reg: 01-07-06
08-17-17 07:35 PM - Post#2704643
    In response to T57
Okay, I've decided that I need a new tank so, why not get one that accepts an in tank pump?
My question is this...The in tank pumps I see are for EFI and have high pressure. Is there a pump that would work with my 2x650 cfm carbs (6-12 PSI) that would match the in tank mounting of the EFI pump?
As always...Thanx for looking.
IBEW
57 belair
ski-doo
Edited by T57 on 08-17-17 07:36 PM. Reason for edit: No reason given.
08-18-17 03:01 PM - Post#2704716
    In response to T57
The TBI setups for 88-95 Chevy pickups were only 12-13 psi. They had in tank pumps that look very similar to the higher pressure Chevy EFI pumps.
Thing is, the pump doesn't determine the pressure, the pressure regulator does. So you can use a pump rated for high pressure, and use a regulator that will adjust to the correct pressure.
I would recommend that you get an adjustable regulator and mount it in the engine compartment where you can adjust it without crawling under the car.
I would recommend the Tanks Inc. tank. Good tank, good price. Contact them for a pump/regulator setup. Aeromotive sells the same tank also and should have carb regulator setups too.
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
08-19-17 08:32 AM - Post#2704796
    In response to T57
Or add this, dual pick up to electric pump, just a thought
Attachment: image.jpg (149.18 KB) 8 View(s)
VC56S 2 door Sedan, 37 Years
[image]http://chevytalk.org/sm/3564.jpg[/image]
08-22-17 10:47 PM - Post#2705280
    In response to T57
i would add an oil pressure controlled cube relay to power the pump. just in case.
jel1957
jel1957
Loc: Sugar Land, Texas
Reg: 01-01-04
10-29-17 07:30 AM - Post#2712538
    In response to bobb
I have a Mallory Supercomp 140 fuel pump that I have had on the car for nearly 20 years (my daily driver till 4 years ago). It is above the tank, pulling through about 6 inches of fuel line. I do have it powered by a relay. It works well.
Henrys57wagon
Canadian Regional Coordinator &"12th Year" Silver Supporting Member
Henrys57wagon
Loc: Carleton Place ON, Canada
Reg: 04-15-06
11-02-17 05:23 AM - Post#2713037
    In response to jel1957
I put an inline pump on mine for EFI(30PSI) on the frame rail.
Here is how I did the return to the tank.
Put the regulator/ return line under the DR fender.
57 B/A wagon, 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 07 2500HD with 26 Prowler 5th wheel, 09 Impala LT, John Deere lawn tractor,
http://www.picturetrail.com/sfx/album/listing/use r...
Execution time: 0.234 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:13 PM
