Octane LightingNu-Relics Power Windows
Username Post: Oil pans        (Topic#346548)
Am4wag
Reg: 11-19-15
08-13-17 05:38 AM - Post#2703971
https://www.opgi.com/el-camino/1969/engine s-compon...
At 4 quarts,is this suitable for 450-500 hp.on the street?
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
Edited by Am4wag on 08-13-17 05:39 AM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-13-17 10:14 AM - Post#2703987
    In response to Am4wag
Id say its a VERY bad idea personally
,1964-77 El Camino Oil Pan, Big-Block Generation V & VI
if you shop carefully you can find a reasonably priced 7 quart oil pan that should help engine durability.
SHOP CAREFULLY , WHEN YOU GO TO BUY AN OIL PAN for your engine or transmission, <AND ASK LOTS OF QUESTIONS ABOUT WHAT WILL FIT YOUR CAR CORRECTLY AND ASK FOR SUGGESTIONS ON MATCHING COMPONENTS OR PARTS THAT WON,T FIT
MILODON,
http://www.milodon.com/
CHAMP
http://www.champpans.com/products/c/oil-pans/
CANTON,
https://www.cantonracingproducts.com/category/1501...
MOROSO
http://www.moroso.com/
http://www.shopmoroso.com/eb/catalog/navigation Pat...
AVIAID
http://aviaid.com/shopsite_sc/store/htm l/ws_oilpns...
STEFS
http://www.stefs.com/products/oilpans/circ letrackw...
HAMBURGERPERFORMANCE
http://www.hamburgersperformance.com/
KEVKO
https://kevko.myshopify.com/
IF you've wondered why I suggest buying and using a well designed BAFFLED oil pan with 7-8 quart capacity its to prevent the oil from uncovering the oil pump pick-up under performance use.
without control baffles oil sloshes away from the oil pump pick-up
Edited by grumpyvette on 08-13-17 10:43 AM. Reason for edit: No reason given.
