Username Post: Power Brake Booster. Help!        (Topic#346537)
kstute12
Reg: 07-29-17
08-12-17 08:56 AM - Post#2703870
I have a 1970 Impala with drum brakes all around. I don't want to break the bank and convert over to disc brakes. So I want to just put a power brake booster on there. I'm at a crossroad because it seems like all these kits fit for every car but the 1970 model which is a pain in the censored anyways for parts. I bought a 8'dual booster which does not line up so I'd have to drill into the firewall and even then I'm not sure because with the brackets it's super long in length. Then there is a 9' dual that lines up perfectly but it's to round so it interferes with the wiper motor. It can't be this hard to get power brakes on this impala since it was an option that year. There is just no space under the hood for this model. Does anyone have any suggestions?
toro455
toro455
Loc: Western NY
Reg: 06-15-02
08-12-17 06:36 PM - Post#2703944
    In response to kstute12
Hopefully somebody here will know but you could also try phoning The Right Stuff Detailing. They sell individual brackets and boosters and generally have very good information of their website if you want to start by looking before calling.
https://www.getdiscbrakes.com/
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
08-14-17 07:14 AM - Post#2704086
    In response to toro455
Why not just use the factory brake booster for drum brakes?
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
08-15-17 06:47 AM - Post#2704303
    In response to BigDogSS
I don't understand??? Like the previous post said just get a replacement 70 booster?
kstute12
Reg: 07-29-17
08-17-17 04:23 PM - Post#2704618
because I have yet to find one that fits correctly all the aftermarket stuff is off the factory ones are 9 in....all the 9in ones are too big and get in the way of the wiper motor.
rooks
rooks
Loc: Australia
Reg: 02-03-10
08-17-17 10:35 PM - Post#2704650
Might be an idea to start by listing the measurements for the mounting holes.
~ Aussie '67 Impala 4 Door Pillarless
~ Factory RHD '67 C10
~ Russ
Edited by rooks on 08-17-17 10:36 PM. Reason for edit: No reason given.
rooks
rooks
Loc: Australia
Reg: 02-03-10
08-17-17 10:47 PM - Post#2704651
    In response to rooks
Also, the stock unit, which is a single diaphragm 11" unit, should bolt right up.
Also, if you're trying aftermarket kits, don't use one with brackets. The booster in the fullsize Chev's should mount flush to the firewall.
~ Russ
sz0k30
sz0k30
Reg: 10-12-08
08-18-17 05:41 AM - Post#2704669
Instead of looking for aftermarket stuff just go into almost any auto parts store & get a 1970 replacement booster. Or I just looked at the Summit website and they had a bunch of different sizes including 1 that was listed at 11" with an angled mounting bracket #SUM-760165. They also had 1 that looks original that mounts directly to the firewall without a bracket a Cardone #54-71101. Not sure whether a 70 booster had an angle mount bracket or not.
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
08-18-17 07:15 AM - Post#2704678
Post some pictures of what you are trying to do.
Execution time: 0.189 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:08 AM
