Username Post: S10 Sonoma ZQ8 4.3L 5spd Replacement Stainless Exhaust?        (Topic#346481)
toro455
toro455
Loc: Western NY
Reg: 06-15-02
08-08-17 08:02 PM - Post#2703454
All,
I recently tried to find a replacement "Y" pipe for my 2003 Sonoma ZQ8 and I cannot find anybody who makes a stainless (or any) replacement for my combination which is 4.3L and 5spd manual. Has anyone else found a solution or modified one of the ones available for a different combination?
Thanks,
Scott
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
08-08-17 10:30 PM - Post#2703465
    In response to toro455
Your best bet is probably going to be an exhaust shop. Bragging rights aside for using stainless, aluminized steel will last a very long time, and you can increase the pencil sized pipe that they used from the factory. I bumped mine up to 2.25"
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
toro455
toro455
Loc: Western NY
Reg: 06-15-02
08-09-17 04:15 PM - Post#2703573
    In response to SleeperSS
Thanks. It's just whenever the muffler shops see a 1 pc part with 2 converters their eyes gloss over with dollar signs. Considering 2 cats the stainless pipes I see on summit are reasonably priced; just nothing 2wd 4.3L manual. Before looking I assumed I would be money ahead by finding the part myself or at least have something which would last forever for the same price as other options.
At this point I wouldn't mind finding anything that would be a bolt-in and the original exhaust lasted over 14 years. The muffler shops do sometimes have their own catalog of pipes so that might need to be the solution.
2plus2
Loc: Mission,BC
Reg: 02-03-05
08-12-17 09:43 PM - Post#2703957
The full size trucks also ran dual cats and 4.3s with 5spds,might have to modify the rest of the system though
And the 99+ trucks used stainless pipes,not sure if the aftermarket will be the same
69 Canadian Pontiac 2+2
Edited by 2plus2 on 08-12-17 09:44 PM. Reason for edit: No reason given.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
08-19-17 08:01 PM - Post#2704849
    In response to 2plus2
Ok thanks, I will keep in mind the 99+ full size configuration to see if it looks similar.
I found aftermarket for seemingly every combination of s10/sonoma except 4.3L with 5spd. I need to find my notes but it looked to me like a combination of 2 existing PNs would work. When I called the company directly they told me nicely that if it were that simple they would have offered the part...
toro455
toro455
Loc: Western NY
Reg: 06-15-02
01-01-18 10:50 AM - Post#2719669
Just an update. The local Monroe shop didn't show a listing for my combination. They said they could do it but they only work with plain steel. I went to a place I've used in the past which re-made the "Y" section from 409 Stainless 2". He was able to replace just the "Y" without having to touch the catalysts.
I didn't end-up checking the full size but actually think one of the Walker "Y" PNs was quite close. It would have been an expensive proposition to buy one to cut though and all I really wanted was something which would last, didn't leak and matched close to the factory routing.
Scott
Execution time: 0.348 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:02 AM
