Username Post: Compression        (Topic#346422)
Airlifter
Airlifter
Reg: 06-07-15
08-05-17 05:25 PM - Post#2702965
Car had a miss so I pulled plug wires and found that #3 was the culprit. I pulled the plug and I was very sooty. I checked to see that there was spark to that point. There was spark there so I changed the plug. Still had the miss so I checked compression. All cylinders were 125 except #3.It was 65. The valves have recently been adjusted.
I reset #3 according to the book and it did not help. I readjusted #3 until I could just turn the pushrods. The compression was still only 65lbs.
The engine has about five hundred miles since complete rebuild.
Someone please tell me that I overlooked something simple.
1951 styline deluxe sport coupe w/54 engine & powerglide
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
08-05-17 08:33 PM - Post#2702987
    In response to Airlifter
Hi Airlifter, Personally I would loosen off the lifters on No3 to make sure they let the valve seat. Say to spec or 5-10 thou loose. Also spin the pushrods to make sure they are free and hopefully still straight. And check you haven't got a broken valve spring. Then redo the compression.
If that doesn't fix it then you need to do a wet test to see if that changes anything. It's just the same compression test with a few squirts of oil in the bores. (Just do No3.)
With the engine running does it make a chuff chuff sound out the exhaust?
Or does it do the same in the intake?
Is there water in the oil, looks like mayonnaise?
You could also look for bubbles in the radiator to check on the head gasket, but a chemical sniff test like a teekay is more accurate.
I am hoping you pooched the setting on the No3 valves as otherwise that's sounds quite serious with the comp down 50%
Cheers Kiwi
Edited by Bel Air kiwi on 08-05-17 08:41 PM. Reason for edit: No reason given.
Airlifter
Airlifter
Reg: 06-07-15
08-06-17 03:59 AM - Post#2703002
    In response to Bel Air kiwi
I loosened the adjustment until I could spin the push rods before I did the last compression test. I did not notice anything different at the exhaust.
I did not check for broken valve spring. Will do that today. I will also do a wet compression test.
The oil looks good.
Edited by Airlifter on 08-06-17 04:03 AM. Reason for edit: No reason given.
50hotrod
50hotrod
Reg: 07-25-11
08-06-17 05:58 AM - Post#2703008
Did you run the engine after the corrected valve adjustment?
You might have accumulated soot on a valve and seat in that cylinder.
People done gone put their Bible's away
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
08-06-17 12:04 PM - Post#2703039
    In response to 50hotrod
Perform a leak down test to find out for sure if you have a valve or bottom end issue
If it is a valve as shitty as it is to fail after 500 miles a head come off easy
Airlifter
Airlifter
Reg: 06-07-15
08-06-17 06:22 PM - Post#2703100
Did a wet compression test and it was still only 50lb.
I turned the engine a few times with the compression gauge installed and let set for a few hours and the pressure stayed at 50.
I backed the adjustment off enough to get a little clearance and tried it again. Still no joy.
Thanks everone
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
08-06-17 09:03 PM - Post#2703117
Hi Airlifter, No rise with oil means you are not normally looking at rings. So that sounds as if it's a valve, bad head gasket, or possibly a big hole in a piston, but that is not so common.
Did you re-torque the head after running it for a while?
Have you turned it over by hand to confirm that both valves on No3 are opening and closing. And have clearance when closed.
Do you have a TeeKay, sniff tester or can you borrow one. That would confirm combustion gass in the coolant which is a head gasket normally as they usually boil when the head is cracked.
To make a simple leak down tester I braize an airline fitting into an old spark plug with the porcelain broken out. Do that under a rag as the porcelain shard will cut your eyes badly. I squish them in a big vise.
Turn the motor so the distributor is pointing at TDC for No3 and confirm both valves are closed. Take off the radiator cap, oil filler cap and aircleaner.
Start with about 50-70 Psi. Put your fitting in the plug hole with the handbrake on and in gear or park so the motor stays still.
If the air comes out of the carb, intake valve. If it comes out the exhaust pipe, exhaust valve. if it bubbles in the radiator, head gasket.
If you can hear it in the rocker cover then its piston/rings/or head gasket.
Unfortunately nothing in the rules says it has to be just one thing.
Cheers kiwi
Edited by Bel Air kiwi on 08-06-17 09:07 PM. Reason for edit: No reason given.
steve65
steve65
Loc: new westminster bc
Reg: 09-25-13
08-07-17 07:48 AM - Post#2703146
dont most compressions gauges stay at the highest reading untill you press the release valve? Try that same test again and press the button and see it its still holding.
Steve Duncan
65 Impala SS Convertible
Ermine White/ Black Top
357 4 spd auto
www.picturetrail.com/steved65
50hotrod
50hotrod
Reg: 07-25-11
08-07-17 08:48 AM - Post#2703153
Was it a local shop that did the engine rebuild? If so, I'd contact them.
Airlifter
Airlifter
Reg: 06-07-15
08-07-17 10:53 AM - Post#2703160
I have been in contact with them and they have been working with me. I am taking the car to them, hopefully, this week to do a leak down test and give a diagnosis.
I am going to be gone for a couple weeks so it might be a while until I get back to working on the car.
Yes, the pressure reading stays on the gauge until it is released. Sometimes have brain fade and overlook the obvious. Lol
Toqwik
Toqwik
Loc: Middleburg, FL
Reg: 05-14-17
08-07-17 07:16 PM - Post#2703246
Sounds to me for some reason you have a valve that is not closing for some reason. Guide too tight, bad spring, something. Hopefully there isn't a nut down there that was dropped that is holding it open. Don't ask me how I know.
Contentment is the smother of invention
Airlifter
Airlifter
Reg: 06-07-15
09-11-17 01:26 PM - Post#2707402
    In response to Toqwik
Finally got the car to the builder to get leak down test. He checked numbers 1, 2 and three to get a comparison. All three read about 20% leakage. This seems a little high for a freshly rebuilt engine. Found one valve spring out of the boss on the bottom. He put it back in place but it made no difference. Still 50 lb. compression on number 3.
I had to leave and he said he would call tomorrow.
Any thoughts on next step?
09-11-17 01:46 PM - Post#2707405
One question I would ask is whether air could be heard escaping into the crankcase or out the exhaust or up the intake tract, this is the normal procedure for pinpointing the source of a bad leak down.
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
09-11-17 01:49 PM - Post#2707406
At this point I would pull the head and inspect
You can pull the head with the manifolds installed
Just be heavy is all and take a good look at the insides
Like kiwi stated if your lucky it's a head gasket issue
Maybe a bent or stuck valve
Was this a full brand new rebuild with new parts? Or a ring job and lap the valves?
Saw it more the once when I worked at jaguar a v12 with low mileage that sat for a long time , and then was drive get carbon stuck between the valve and seat and cause it to run rough
We would do a motorvac on it the drive it in 2nd gear on the Hwy. The smoke show out the exhaust was incredible !!!
New plugs afterwards and that v12 purred just right for a day or two !!!lol
A long shot if this was a full on rebuild but a possibility if it was just cleaned up
Or a collapsed lifted? Bent push rod?
Airlifter
Airlifter
Reg: 06-07-15
09-11-17 04:16 PM - Post#2707417
    In response to VANDENPLAS
This was a full rebuild with all new parts.
Airlifter
Airlifter
Reg: 06-07-15
09-12-17 04:53 PM - Post#2707510
They are going to pull the head Thursday. Is it possible that an extremely rich mixture could cause a valve to stick? Also, is it possible that a vacuum leak could cause a valve to stick? I have never heard of this but I have a reason for asking.
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
09-12-17 06:24 PM - Post#2707515
Not that I have ever seen or heard of but anything is possible
2blu52
2blu52
Reg: 03-12-02
09-12-17 06:28 PM - Post#2707517
A vacuum leak is a primary cause of burning valves, it causes a lean out condition. Who installed the intake exhaust manifolds?
THOMAS JEFFERSON
Airlifter
Airlifter
Reg: 06-07-15
09-12-17 07:10 PM - Post#2707519
    In response to 2blu52
A mechanic friend helped me install the manifolds. We checked for vacuum leaks with carb cleaner.
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
09-13-17 07:20 AM - Post#2707553
What's your no. 3 plug telling you, i. e., oily, rich, lean, or maybe you haven't ran it long enough.
50s Chevys http://www.picturetrail.com/sfx/album/view/245196 4...
50hotrod
50hotrod
Reg: 07-25-11
09-13-17 08:00 AM - Post#2707555
Rich condition would not cause any problems other then spark plug fowling in the short amount of time you had the engine running.
A vacuum leak can burn the valves as already mentioned but would also affect the idle of the engine. Did the engine idle ok?
Kinda sounds like the repair shop is looking for ways to get around blame for the problem.
2blu52
2blu52
Reg: 03-12-02
09-13-17 01:39 PM - Post#2707575
"I have never of of this but I have a reason for asking"
That is an interesting statement, possibly if you tell us the reason for asking we could find something that helps here.
THOMAS JEFFERSON
Airlifter
Airlifter
Reg: 06-07-15
09-13-17 04:12 PM - Post#2707592
You probably figured out the reason. This is what the builder was suggesting.
I was having problems with idling for a while but it seemed to be ok after we adjusted the carburetor. As I mentioned earlier, we checked everywhere for a vacuum leak.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
09-13-17 05:02 PM - Post#2707598
Hi, did you check the actual running of the engine with a sensitive vacuum gauge.
Sometimes it can be very hard to find vac leaks when you are not sure if they are the real cause.
lean mixtures can cause overheating of individual cylinders and that may affect a valve, but sticking would be unusual. Lack of assembly lube could have caused stem galling and this is also common with long sitting engines.
The soft tap on the top of the valve will tell you whats going on there.
It is always a good idea if you are bringing an engine back to life. Pull the plugs and lube the bores lightly, take off the rocker covers and make sure the valves are lubed and moving freely before you try cranking it.
You can turn a runner into a rebuilder by dry starting something that has sat for a long time.
Cheers kiwi
Edited by Bel Air kiwi on 09-13-17 05:03 PM. Reason for edit: No reason given.
Execution time: 0.41 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:01 AM
