Octane LightingNu-Relics Power Windows
Username Post: Transfer Case Question        (Topic#346385)
Fossil_Fuel
Fossil_Fuel
Loc: Minnesota
Reg: 09-11-07
08-03-17 02:58 PM - Post#2702695
My 1976 K10 will not go into 4 Hi anymore. Does anyone have some suggestions on what to check first?
It shifts to the other positions just fine but it will not budge when trying to shift to 4 High.
It does not get driven much and was sitting for many years before I got it but it has always shifted into 4 Hi for me until now.
It is all factory original drivetrain, etc.
Thanks in advance for any help.
Attachment: IMG_4373.JPG (2.84 MB) 4 View(s)
Attachment: 76_Chev_008.jpg (154.11 KB) 4 View(s)
Attachment: 76_Silverado_Options_card.jpg (1.98 MB) 5 View(s)
1964 Impala SS 327/300 since '76
1967 Impala SS 327 Triple Black Hardtop in the works
1967 Impala 327 Bench Seat 4-speed
http://craigaacars.shutterfly.com/pictures
Edited by Fossil_Fuel on 08-03-17 03:04 PM. Reason for edit: No reason given.
LMC Truck
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-03-17 07:23 PM - Post#2702724
    In response to Fossil_Fuel
When you pull the lever is there movement with resistance or it just stops dead?
I would have a look at the linkage under the truck. I lubricate mine every year.
If that does not help pop the linkage off and try putting it into 4hi at the transfer case.
Best of luck. Nice truck
Old School GM fan FOREVER
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
08-04-17 10:50 AM - Post#2702791
    In response to rockfangd
I'm not sure that I inderstand you because in my 76, you had to go thru 4H in order to get to N and 4L.
Sooooo, you you mean that it goes in to 4H and then when you let out the clutch the truck won't move
Fossil_Fuel
Fossil_Fuel
Loc: Minnesota
Reg: 09-11-07
08-04-17 02:06 PM - Post#2702815
    In response to Stinky
Not on the '76
The order from front to back goes:
L(loc), L, N, H, H(loc)
I can shift into all except H(loc)
No clutch by the way. Automatic transmission.
Attachment: image.jpg (2.46 MB) 3 View(s)
2plus2
2plus2
Loc: Langley,BC
Reg: 02-03-05
08-05-17 12:00 PM - Post#2702936
Sounds like the shifter is worn out if the other ranges work
That tcase uses a shifter and 2 rods
1 rod controls high-n-low and the other controls lock and unlock
Google np203 twin stick if you want a upgrade
69 Canadian Pontiac 2+2
Edited by 2plus2 on 08-05-17 12:03 PM. Reason for edit: No reason given.
elcamino
elcamino
Reg: 03-30-00
08-09-17 03:55 PM - Post#2703569
Remove the floor boot and spray heavily with some good rust penetrate and let it soak for a while. Might be just rusted from inactivity.
This is the best stuff...
2015 GMC Sierra Denali 6.2L (420hp) Crew Cab Standard Box 4WD
2016 Polaris RZR 900 EPS
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-15-17 05:57 PM - Post#2704369
    In response to elcamino
agree with above.
Gets pretty nasty under there
LMC Truck
Execution time: 0.391 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:40 PM
