Username Post: Kinda losing my mind with spark plugs        (Topic#346384)
Flying_Dodo
Flying_Dodo
Reg: 07-11-17
08-03-17 12:49 PM - Post#2702672
What I pulled out of the truck were ACDELCO R45TS. 14mm thread.
Guys at advance auto game me the wrong ones altogether. Some 18mm things (for the 323 maybe?)
I'm getting conflicting information on the PROPER spark plugs for this engine.
I picked up ACDELCO R45S, which won't thread.
Summit seems to think they will, but they don't.
Dunno why not, they are a 14mm thread.
I guess the question is, wtf spark plugs do I put in this thing?
Thanks.
bobschevytrucks.com Ecklers
Flying_Dodo
Flying_Dodo
Reg: 07-11-17
08-03-17 01:07 PM - Post#2702673
    In response to Flying_Dodo
OK, figured out why the R45S do not work. This engine requires the T, or tapered 5/8 socket for the plug threads to even reach to head.
Sorry, like I said, new to these engines.
Why does no site I've looked at so far list this?
Do I even have a 327? I haven't looked at the engine numbers. Kinda dirty down there.
08-03-17 01:44 PM - Post#2702678
The "T" in the spark plug no. means tapered seat. These are the plugs with the 5/8" hex that do not use a washer or gasket. The taper on the plug seals directly against a matching taper in the head.
I don't know what year the tapered seat heads were first used, so can't help you determine whether or not the heads are original to the truck. To identify what engine you have, please post the stamped number you will find on the block deck just in front of the RH head.
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
08-03-17 04:45 PM - Post#2702707
Since the heads on these engines are interchangable, you may want to pull a valve cover and see what the casting number of the head is.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
Flying_Dodo
Flying_Dodo
Reg: 07-11-17
08-03-17 05:24 PM - Post#2702710
I think I've found a solution. A freshly rebuilt 350 for 800 bucks.
Then I can spend time rebuilding this damned (supposed) 327.
Execution time: 0.264 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:53 PM
