Username Post: 48 fleetline differential        (Topic#346378)
edgar101
Reg: 08-28-10
08-03-17 06:28 AM - Post#2702633
Thinking about putting an LS engine in my 48. If I do, does anyone have any suggestions on what rear end to use that would fit?
08-03-17 09:39 AM - Post#2702655
    In response to edgar101
What bolt pattern will you be running on the front? I assume you want front & rear to match?
08-03-17 07:13 PM - Post#2702721
55-57 will work. Just need to drill the spring pin hole 1 1/2 inch ahead on the spring perch.
It is 5 lug.
Broo102
Broo102
Loc: RANCHO CUCAMONGA, CA.
Reg: 09-30-14
08-06-17 09:50 AM - Post#2703028
Yes the 55 to 57 has same perch locations, make sure your axles and R & P are beefed up though.
I used 67 camaro rear end, but I wish I used 55 t0 57 set, it was a lot of extra work relocating those perches!
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Execution time: 0.258 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:20 AM
