 Page 5 of 5 « First<2345
Username Post: what is this box thing on the drivers side of the engine bay?        (Topic#346360)
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
12-17-17 10:30 PM - Post#2718321
    In response to Eric_Gary132
it can also be from a 63-66 GMC which had a different zbar than the chev one. it also appears to be longer as the frame end bracket sticks out over the side of the frame
ron
http://www.sawmillcreek.org/showthread.php?208929-...
http://www.sawmillcreek.org/showthread.php?220902-...
http://forum.woodenboat.com/showthread.php?156542-...
Ecklers
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
12-17-17 11:10 PM - Post#2718324
    In response to sidworks
linkage is designed that it runs true or should align where it joins and be friction free - not be able to bind as is the case where the linkage rod joins at the zbar. there is the potential for it to bind on that corner when the pedal is depressed which can be intermittent as it going into gear 1 time and not the next or the difference as to how one driver depresses the clutch vs another. it also looks that it may have also have the opportunity to bind where it comes out of the firewall. there could be a combination of other things accumulating the problem such as worn shifter forks if they are worn. if you have a known problem area that should eliminated
ron
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
12-17-17 11:17 PM - Post#2718325
  • Eric_Gary132 Said:
there's around 2 to 3 inches of releasing the clutch before it engages.
we had 2 shops drive it and at first they told us it drove fine when they test drove it and we know it does not. Sometimes it will work and sometimes it will not and it repeats this process.
oh and correct me if I'm wrong but, I belive the zbar in our truck is a 67-72 zbar or a 73-84 zbar, not the correct years to use with mechanical linkage in this truck, which you said was a 63-66 zbar. Which would explain the incorrect position of the arm of the zbar in this truck, the upper arm in particular that the upper rod connects to.
My rookie idea is that they took any old zbar they could find and forced it in or somehow cut it shorter to fit just enough to connect the rods to it, rather than getting the correct parts.
I found a 63-66 clutch zbar here:
https://www.classicparts.com/63-66-Clutch-Cross-Sh ...
the one thing that I will note is that you never ever answer the full questions. here you answered 1 out of 3 and then started rambling on about another aspect of it.
sometimes it is like trying to pull teeth from a chicken
ron
Eric_Gary132
Loc: northern California
Reg: 01-27-17
12-20-17 04:12 PM - Post#2718589
my grandfather tried contacting you, but no one is answering? whats the best time to contact you?
Edited by Eric_Gary132 on 12-20-17 04:16 PM. Reason for edit: No reason given.
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
12-20-17 04:27 PM - Post#2718591
i just checked my call log and no calls in from US.
that nbr in the PM is always with me,
ron
Eric_Gary132
Reg: 01-27-17
12-20-17 04:44 PM - Post#2718592
my grandfather keeps calling you but it wont go through i will PM you his number.
Edited by Eric_Gary132 on 12-20-17 06:36 PM. Reason for edit: No reason given.
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
12-20-17 06:50 PM - Post#2718607
I did get 1 private nbr call just 3;00 this afternoon but it was a hangup when I answered it. I do get calls from down there quite frequently so it does work
my nbr is a business nbr and has been working for me for just over 25 years at this location
ron
Edited by sidworks on 12-20-17 07:06 PM. Reason for edit: No reason given.
Eric_Gary132
Reg: 01-27-17
12-20-17 06:57 PM - Post#2718610
Edited by Eric_Gary132 on 12-20-17 06:59 PM. Reason for edit: No reason given.
hilandr451
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
12-21-17 12:08 PM - Post#2718671
My hat is off to you sir, for going the extra mile in helping this lad & his Grampa fix their truck.
It's people like you, Ron, that make this site what it is! (colorful comments included )
A sincere salute to "The Captain"!
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L,
1966 C20 Custom Camper "Rattle can primer red" 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
12-22-17 07:41 PM - Post#2718817
    In response to hilandr451
i think I am going to cut this one out and paste it on the wall
I still have all those PM's from you saying other things
Have a Merry Christmas down there in Texas
ron
Ecklers
Execution time: 0.169 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:20 PM
