Username Post: brake vac. canister        (Topic#346315)
rocktober
Reg: 03-05-17
07-31-17 02:08 PM - Post#2702200
need idea for brake vac. canister, friend said old juice cans, lol ,..... also can't seem to stay logged in on this site
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
07-31-17 04:50 PM - Post#2702226
    In response to rocktober
" old juice cans" if you look at some fords from the 70's - 80's had an apple juice can as the vac canister!
Chevrolet has used a variety of vac canister from small round ones in late 90's blazers to large rectangular blobs in some 80's 90's fwd cars
Find something that will work and hide it
If you want to get creative anything with 2 ports that can hold pressure can hold vacuum
rocktober
Reg: 03-05-17
07-31-17 05:39 PM - Post#2702247
    In response to VANDENPLAS
thanks
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
08-01-17 12:43 AM - Post#2702284
Hi Rocktober, The more vacuum you want to have the tank hold the better the design must resist collapse from atmospheric pressure. That is the more structural it needs to be.
The early tanks only held what the engine could produce so they looked like giant pills with rounded end tubes and a check valve.
If you want a new one all the usual suppliers like summit ,jegs, amazon etc have the fairly standard tubular type but they are either heavier wall alloy or small. (I run one on my street class drag car.)
This tray of eggs design was from memory a Ford trick and they used it for radiator pressure tanks and vacuum tanks.
The last one is more your late model euro turbo diesel car so is probably from VW/Audis which run the electric vacuum pump for brakes.
Obviously the pure sphere is the strongest shape which allows them to be made of plastic, and hold against 20+ "Hg. no problem.
Cheers Kiwi
Attachment: vacuum_tank_with_check_valve.jpg (32.63 KB) 4 View(s)
Attachment: vacuum_tank_aftermarket.jpg (24.58 KB) 4 View(s)
Attachment: Vacuum_tank_modern_OE.JPG (143.96 KB) 4 View(s)
Attachment: Vacuum_tank_OE_2.jpg (200.62 KB) 5 View(s)
rocktober
Reg: 03-05-17
08-10-17 05:20 PM - Post#2703694
    In response to Bel Air kiwi
thanks ,... i put 11 in. wildwood brakes on the front, drilled disc., slotted, improved the braking about 25 percent on the first two to three, pushes, , may a vac. canister later, ...but i read , and about half the people think that a vac. canister won't help!!
08-10-17 05:33 PM - Post#2703696
A canister doesn't make vacuum. It just stores vacuum. If your engine doesn't make enough vacuum to start with, a canister won't help any. Then you will need an electric vacuum pump.
rocktober
Reg: 03-05-17
08-11-17 06:19 AM - Post#2703746
thanks makes sense ,
rocktober
Reg: 03-05-17
08-11-17 06:21 AM - Post#2703748
what if i move my 7 in. booster from under the car and put a 11. booster back under the hood, ya think this would be a good help?... thanks
08-11-17 08:12 AM - Post#2703761
If you have low vacuum, a larger booster will always be better than a smaller one. Can you mount an 11" booster on the firewall without clearance issues?
rocktober
Reg: 03-05-17
08-11-17 08:16 AM - Post#2703762
yes i have room, some was telling about a dual diafame booster
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
08-12-17 04:04 AM - Post#2703844
Hi rocktober, Dual diaphragm boosters are a bit of a space saving fudge.
Before you start throwing money around you need to put a vacuum gauge on your engine and drive it around a bit. Record the values.
Boosters are just effort multipliers. They rely on a difference in area and a difference in pressure.
So not much area (small booster) and/or not much vacuum and you won't get much assist.
Big disc setups need more than double the line pressure of drum setups, and more, to work to their best. So you need a reliable boost ratio of over 2.0:1.
Brake boosters in the aftermarket are rated on a fantasy figure of 23"Hg that you won't get in the real world.
So if you are running half that vacuum then you need to deal with that by an alternate means.
Fortunately turbo diesel cars and pickups have no manifold vacuum and they have pumps that you can retrofit. They generally pull about 20"Hg of mercury and in combination with a tank will give you lots of repeatable stopping.
Downside is the mechanical ones on alternators need an oil feed and the electric ones are quite noisy like competition fuel pumps.
Cheers kiwi
rocktober
Reg: 03-05-17
08-12-17 12:54 PM - Post#2703891
https://www.mpbrakes.com/accessories/silent-dr ive-... anyone heard of these guy ? he says running this i'll have 18 vac. all the time, i can unhook my motor vac.
08-12-17 02:53 PM - Post#2703900
For $600 I know I could put up with a bit of noise. Besides, an electric pump doesn't have to run all the time. You can use it with a canister and a vacuum switch, and then it will run only when needed.
50hotrod
50hotrod
Reg: 07-25-11
08-12-17 04:50 PM - Post#2703926
There are cheaper vacuum pumps out there.
http://www.ebay.com/itm/12-volt-electric- vacuum-pu...
People done gone put their Bible's away
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
08-14-17 09:29 PM - Post#2704256
    In response to 50hotrod
Hi Rocktober, Have you got a figure for your engine vacuum yet?
As 50 Hotrod has said there are a lot of cheaper kits out there than that one. Plus you can go to the breakers yard and get a Quality pump from Hella from a Volvo, and also VW, Audi as well.
That ebay kit claims 18-23"Hg continuous vacuum so if it does that then that is fine.
The problem is a lot of sellers rate their product on unrestricted free-flow tests.
The fan and pump guys in particular.
But what use is a 3000 cfm radiator fan if it can only do that without a radiator in front of or behind it. Or a 110 GPh fuel pump that can only do that without filters and in a bucket to bucket test stationery. Or a brake booster that can only meet spec at an inlet vacuum of 23"Hg when you are lucky to have 18"Hg.
Cheers kiwi
Attachment: Hella_Volvo_vacuum_brake_pump.jpg (65.15 KB) 3 View(s)
Execution time: 0.234 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:34 PM
