LMC Truck
Username Post: negative battery clamp bolt        (Topic#346253)
thealexdexter
Reg: 01-03-05
07-27-17 02:14 PM - Post#2701704
2015 Duramax: driver side battery there is a fancy bolt that clamps the negative cable to the battery terminal. I cant find this on any of the GM drawings. Dealer will only sell me the entire negative cable assembly that includes it for $127!
Anyone know where I can buy this stupid little bolt by itself?
The bolt is kind of a shaped head where the head acts like a cam and squeezes the clamp together. Why they couldn't use a simple nut and bolt is beyond me. Cant change to this style because the bolt is parallel to the terminal post rather than perpendicular...so without the cam thing it wont squeeze.
2015 CC 3500 Duramax Sierra All Terrain 4x4 SLT in Black
2008 Yukon Denali in Black
Edited by thealexdexter on 07-27-17 02:15 PM. Reason for edit: No reason given.
LMC Trucks
Matt
Matt
Loc: SAV
Reg: 09-26-01
08-24-17 11:05 AM - Post#2705441
    In response to thealexdexter
Had the same issue as you. Here you go:
https://www.amazon.com/gp/product/B00GTJQ6TA
Matt
Matt
Loc: SAV
Reg: 09-26-01
08-24-17 11:05 AM - Post#2705442
    In response to Matt
GM Part # 19116852
Here you go: https://www.amazon.com/gp/product/B00GTJQ6TA
thealexdexter
Reg: 01-03-05
09-16-17 01:15 PM - Post#2707843
    In response to Matt
Thanks man. For some reason I didn't get notified of your post. Just came here browsing an noticed the response from long ago.
Edited by thealexdexter on 09-16-17 01:16 PM. Reason for edit: No reason given.
LMC Trucks
Execution time: 0.242 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:31 PM
