Username Post: Door mirrors...?        (Topic#346234)
Reg: 07-11-17
07-26-17 11:43 AM - Post#2701540
Looks like this truck (68 fleetside) has never had door mirrors on it. No place where they were mounted before.
Is this normal, and how do I mount new ones (was looking at lmc's door mirrors.)
I did do some google searching and didn't turn up much regarding the fact that there were absolutely zero stock mounting points on this truck.
Cheers. Ecklers
Loc: Liberty, SC
Reg: 08-06-16
07-26-17 05:49 PM - Post#2701576
    In response to Flying_Dodo
This is not mine I found it on my other truck board.
There is suppose to be 3 holes to mount the mirror base. 68 has the holes drilled as follows.
1. 1/2 in down from body line, 2 5/8 from front edge of door.
2. 1/2 in down from body line, 6 1/8 from front edge of door.
3. 1 1/2 in down from body line, 4 1/2 from front edge of door.
4. Holes are 27/64 in dia.
There should be a backing plate with matching threaded holes to go on the inside of the door.
All measurement are to c/L of holes.
Hope this helps.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Reg: 07-11-17
07-27-17 04:49 AM - Post#2701614
    In response to Andy4639
Sure does. I'll see if i can find the backing plate by taking off the inside door panel. Ecklers
Execution time: 0.244 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:19 PM
