Username Post: 94 z28 gas tank neck        (Topic#346194)
173rdherd
173rdherd
Loc: BLACK DIAMOND BAY(tomball...
Reg: 11-29-04
07-24-17 08:39 AM - Post#2701191
i have removed the gas tank and have a replacement tank from spectra sans the neck. the old neck appears to be permanently attached to the tank. is this a fact, or do I need a bigger hammer? This by the way is a very cool Z and has the cold air induction and ultra z hood....also 6 speed.
94 Z-28 Ram Air
76 el camino (Elke)
58 4 dr Yeoman (Nadine)
57 4 dr 150 (Dottie)
53 4 dr tradesman (Tupelo Honey)
and they're all....
Positively Fourth Street.
173rdherd
173rdherd
Reg: 11-29-04
07-25-17 06:07 AM - Post#2701341
    In response to 173rdherd
I got a response from rock auto and they said its a weld on deal, good news is they are only charging $18 for return shipping on tank and issuing refund.
I wish people would post more about problems they encounter on these cars, even when they solve the problem themselves.....it's one of the things that really make this place rock!
94 Z-28 Ram Air
76 el camino (Elke)
and they're all....
77chevy
77chevy
Loc: trusting earth to a boys ...
Reg: 01-26-01
07-28-17 05:25 PM - Post#2701883
sorry days late.
hope you enjoy the 6speed and its fun for you.
you know the fuel pump can be accessed by cutting the trunk floor. measurements can be found online for lt1 vs ls1
if you want a solid drag hook for cheap find the mythical softer v6 springs and cheapo 3rd gen rear shocks. you could score some cheap lower control arm weld on brackets to lay the lower control arms level. make sure the unit is good in the rear and if it isnt go with the yukon units. this setup will not handle but will hook.
Edited by 77chevy on 07-28-17 05:32 PM. Reason for edit: No reason given.
173rdherd
173rdherd
Reg: 11-29-04
11-15-17 06:06 PM - Post#2714557
    In response to 77chevy
finally got back to this project, buttoned up fuel system went to start and security light. evidently the pellet in my key is dead. I know how to find the resistor value when the key is good....but how do I find which one of the 15 different pellets I need when the key is bad?
also....you mean a full size Yukon rearend? I have a 2002 coming available soon. Taking the motor and trans for the 58.....just realized you meant Yukon brand!
94 Z-28 Ram Air
76 el camino (Elke)
and they're all....
Edited by 173rdherd on 11-15-17 06:07 PM. Reason for edit: No reason given.
jktucker92
jktucker92
Reg: 02-05-17
11-20-17 01:56 PM - Post#2715108
Is the pellet in the key actually bad, or is it the wiring from the lock to the BCM? I just replaced my lock on my '99 and the problem was a broken wire to the ignition lock. I was able to get the resistor value by measuring the pellet in the key itself. If the pellet is the key is missing or broken, then the only way I can think of is to just try all the options until it works.
173rdherd
173rdherd
Reg: 11-29-04
12-20-17 04:16 PM - Post#2718598
    In response to jktucker92
sorry for so late.....I think the pellet is bad, but don't know how to find out which one it is
94 Z-28 Ram Air
76 el camino (Elke)
and they're all....
jktucker92
jktucker92
Reg: 02-05-17
01-12-18 11:13 AM - Post#2720864
Sorry, just noticed this post. Not sure why I didn't see it sooner. Usually the failure is in the ignition switch, not the pellet, but it's not unheard of to have the pellet break.
Without a valid pellet in the key, you may have to resort to trial and error with the resistance value. You can buy a set of the possible resistors online. They're often used for remote start systems. They make a bypass key, which will allow you to connect it to each resistor and try them. Look online for instructions on how to do this.
Execution time: 0.433 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:02 PM
