Username Post: Rear Shocks        (Topic#346106)
dpurdy
dpurdy
Loc: Mission B C Canada
Reg: 12-30-06
07-19-17 03:04 PM - Post#2700633
1952 Chev Styline. Anyone installed Gabriel or Monroe rear shocks Need part number. I'm getting conflicting numbers from on-line and local jobber.
Dave
'52 Chev Deluxe Sport Coupe
'69 MGB Tourer
'01 GMC 2500HD daily driver
2blu52
2blu52
Reg: 03-12-02
07-19-17 05:15 PM - Post#2700646
    In response to dpurdy
Do you have the old shocks, there may be a part number on them. Monroe usually did have if my memory is still working correctly.
THOMAS JEFFERSON
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
07-19-17 09:04 PM - Post#2700670
http://salestores.com/frigidairefg261.html?gclid=C...
I think the 5803 is what you need
Dean50
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
07-20-17 01:53 AM - Post#2700677
    In response to Dean50
Hi Dpurdy, they are pretty standard shocks, have you considered going to a premium brand with a bolt, or weld in shock member.
It not only saves the trunk floor it firms up the shock mount making it function as designed.
Great shocks are only bettered by great tires.
Cheers kiwi
07-20-17 11:14 AM - Post#2700725
Monroe 5803 or 33049
Gabriel 82155
All of these are on Rockauto, but they don't all appear in the same listing. To find them, you need to know that all 49-54 Chevy passenger cars take the same shocks.
I agree with Kiwi about installing a crossmember for mounting the shocks. Attaching them to the trunk floor was just cheapness on the part of GM, who really didn't want us keeping these cars for 60+ years.
dpurdy
dpurdy
Reg: 12-30-06
07-20-17 06:21 PM - Post#2700768
Thanks gentlemen. I'll go with the Garbiels. Too lazy to reinforce. For the number of miles it is driven each year, it'll last another 60 with the original mounts!
Dave
'69 MGB Tourer
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
07-21-17 01:58 AM - Post#2700796
Hi Dave, if it doesn't do many miles and they are on soft roads then you could be fine without a member. However metal fatigue is about duty cycles so how many total cycles matters, time not so much. The bolt in kits are probably cheaper than the time and effort to repair the trunk floor.
Cheers kiwi
sparkie93
sparkie93
Loc: Suwanee, GA
Reg: 08-27-10
07-21-17 04:17 AM - Post#2700797
    In response to Bel Air kiwi
Cheers kiwi
Does someone offer a bolt-in stiffening kit?
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
07-21-17 11:24 PM - Post#2700880
    In response to sparkie93
Hi, I think Walton's and others do, its' not a very complicated piece. Just look on their web site or google it.
Cheers kiwi
Edited by Bel Air kiwi on 07-21-17 11:32 PM. Reason for edit: No reason given.
40grit
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
07-22-17 12:20 AM - Post#2700884
Here is a link for anyone modifying their shock mounts and needing a shorter shock. it is a few years old but still has good inforemation.
http://www.shockwarehouse.com/news/pdf/monroe-shoc...
Just Slightly Abrasive
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
07-23-17 07:58 PM - Post#2701120
    In response to 40grit
Hi Guys, Bolt in shock mounts by Waltons.
Cheers kiwi
Attachment: Waltons_shock_mount_1.JPG (83.15 KB) 29 View(s)
Attachment: Waltons_shock_mount_2.JPG (121.36 KB) 26 View(s)
Attachment: Waltons_shock_mount_3.JPG (112.86 KB) 20 View(s)
gregd66
gregd66
Loc: North Alabama
Reg: 02-28-15
01-10-18 11:56 PM - Post#2720755
Hey Kiwi, what shock are you using with the waltons cross member and lowering blocks? I am going with the same setup and need to order shocks. Thanks mate!
54 Belair in progress
64 Chevy swb, 2nd in line
46 Ford coupe, future gasser
66 Mustang, my first car, circa 1983
40 Chevy 2 door sedan
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
01-11-18 06:53 AM - Post#2720766
    In response to gregd66
I'm curious because my Fleetline that had 80k miles on it when I got it, didn't have cracked or broken top shock mounts. This car looked like it had been driven on mostly gravel roads all it's life. The wheel openings and the front of the fuel tank were full of dents caused by, and I am assuming this, rocks hitting them. It had dust under all the moldings and, the frame was full too. But, the shock mounts looked good. If you know what the roads are like in North Dakota even today, you can about imagine how few tarred roads there were back in the early 50's & 60's. Even today it seems as though the fast majority of county and township roads are still not tarred. So, what I am curious about is, how many of you actually had cracked or broken top shock mounts when you got your car?
1950 Fleetline, 350 TBI, 700R4, 3.73 posi rear Blazer axle, MII front
01-12-18 08:26 AM - Post#2720848
Interesting, my shocks are mounted rear of the axle.
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
01-12-18 09:26 AM - Post#2720852
    In response to johnwd98
I too still have shocks attached to original trunk mounts. I'm running booster shocks, and so far no issues. Mileage on car ( if true) is a little more than 67000.
So what can be results if trunk mount fails while driving, other than an obvious sag on that side?
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission.
01-12-18 09:44 AM - Post#2720855
    In response to one4dad
Shocks don't support car weight, if that happens either support plates would be welded in or better, the Walton brace/mount installed,which also helps with frame stiffening.
01-12-18 12:30 PM - Post#2720867
Kiwi is that a Ford rear axle or one from a tri five? I have trouble telling them apart from behind.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-12-18 06:09 PM - Post#2720886
Hi Ray, just a generic picture from online of the shock bracket. Not sure what diff it is. For six cylinder I use a GM Holden type which has a rear exit pumpkin. all though for V8's I would have used a GM Holden One tonner diff with a Ford 9" center. As these were both leaf spring cars.
I use KYB or Koni and sometimes others as shock absorbers are a significant contributor to ride quality and handling.
Cheers Kiwi
01-12-18 07:27 PM - Post#2720891
Sorry, Kiwi, I thought that was one of your cars. Your sig says you have a 51 and a 52, and the frame looks like it could be one of those.
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
01-12-18 09:00 PM - Post#2720901
I think the shock mount failing is a bit of a stretch.
But the waltons or chassis engineering shock mount/rear cross member will defiantly help stiffen up the frame a bit.
When I bought my fleetline between the bumper and fuel tank was welded a 2” X2” square tube from inside of each frame rail. Guessing this was the previous owners attempt at a rear stiffening bar.
It was done well so I’ve left it in.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-13-18 03:55 PM - Post#2720964
    In response to VANDENPLAS
Hi VDP, Some folks have had the trunk torn and as the power and speeds go up it becomes more of an issue.
I don't think Chevy made a mistake with this, they calculated that for the car they made it would do.
So its a calculated cost saving.
In the other variants of our cabin like a Pontiac or Oldsmobile you will find the whole chassis differs but they also have a shock member at the back.
Also as many folks are converting from Torque tube to open drive-line with more power and speed in the car the need for a bit of rear chassis bracing goes up.
Flexing shock absorber top mounts must reduce their effectiveness. If you add coil springs to the shocks or any sort of overload device through the shocks the loads also go up dramatically.
It may not be a vital change, but it is founded in good common sense as it can achieve a couple of things at once.
Cheers Kiwi
PS. Hi Ray, my 52 is stock and unrestored, the second one is the parts car. So both are still Torque tube.
Edited by Bel Air kiwi on 01-13-18 03:57 PM. Reason for edit: No reason given.
Execution time: 1.422 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:52 PM
