Username Post: How low would you go....front fender with coil overs        (Topic#346055)
Duke
Duke
Loc: Earth (sometimes)
Reg: 04-28-03
07-16-17 04:20 PM - Post#2700273
Might be throwing on some front coilovers on my '55, the current ride height of the front fender apex lip is 25". I currently have 2" drop spindles with the 454, original coil springs. Looking to drop the front end a bit. Want to make sure I don't smack the front tire on the fender lip when I am turning or when hitting a bump while steering. It's not a grand-touring ride but nonetheless.
http://s1245.photobucket.com/albums/gg590/MTBingNi ...
'55 Bel Air Sports Coupe
'67 Corvair Monza Convertible
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
07-16-17 09:22 PM - Post#2700301
    In response to Duke
If you already have 2" drop spindles I wouldn't lower it any more. My 64 Biscayne has 2" drop spindles and short coils in the back and is almost too low. Any lower and speed humps would be a real problem. I couldn't see lowering it anymore.
Gary
Nick P
Nick P
Loc: De Queen, Arkansas
Reg: 10-15-03
07-17-17 05:59 AM - Post#2700322
    In response to Duke
Regardless of what may be thought as protocol, coil over shocks shouldn't be considered as a means to an end respective to lowering a vehicle. Granted, one can acquire a degree of minor adjustability but as with any shock, it has a designed ride height/installed height engineered into the product. Violating that suggested length invites disaster or at a minimum damaging a shock. I can attest with some degree of accuracy that mishandling, misuse or improper installation will void any warranty. Suspension systems are a means of allowing movement within the unit - disturbing that design intent simply produces unwanted results. If lower is desired, purchase Control arms that will yield the results wanted and continuance of suspension travel/handling.
Sorry for the long reply.
Nick
Execution time: 0.325 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:56 PM
