Username Post: powerglide kick-down adjust        (Topic#346043)
john_johnson
Loc: Chattanooga, TN
Reg: 08-31-07
07-16-17 05:39 AM - Post#2700223
How do you adjust and/or make your kickdown downshift work? Ive tried adjusting how high the kickdown lever goes.
Nothing seems to make it downshift with the gas pedal
"That's all I have to say about that!"
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
07-16-17 11:27 AM - Post#2700248
    In response to john_johnson
6 or 8 cylinder?
At the present does it stay ln low longer if the gas pedal it pressed down farther?
john_johnson
Reg: 08-31-07
07-16-17 06:16 PM - Post#2700283
    In response to Gene_Schneider
Its a 235 six - no it shifts normal and right where it should
john_johnson
Reg: 08-31-07
07-16-17 06:18 PM - Post#2700284
I re read your question - yes it stays in 1 longer if i floor it from a dead stop
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
07-20-17 08:05 AM - Post#2700698
First make sure te linkage is pulling the carbureator wide open when floored. If it is check diagram in shop manual for adjusting linkage on a 6 cyl. engine.
john_johnson
Reg: 08-31-07
07-20-17 09:46 AM - Post#2700711
Good advice ! Thanks ! I have noticed that it does not seem to be wide open when I floor it, the pedal travel seems small.
john_johnson
Reg: 08-31-07
07-28-17 05:39 AM - Post#2701811
ok - fooling around with all tge accelatir rods adjusting them fixed it - my gas pedal really has good travel now - AND - my oke fashioned cast iron downshifts and kicks censored when i floor it!
Thanks Gene!
Save the all-originals, 6 cylinders, and cast pglides!
Execution time: 0.292 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:44 PM
