Username Post: No Fuel To Carb        (Topic#346038)
KansasMike
Loc: Kansas
Reg: 07-26-15
07-15-17 04:19 PM - Post#2700179
1961 Apache 10 w/235 sputtered to a stop today. Half a tank of gas and no fuel to carb. Pulled inline filter off and cranked engine. No fuel. Pulled input line from fuel pump and no fuel came out. I remember when I changed out the pump last year, fuel poured out the input line. This leads me to think I've got an obstruction somewhere. Correct thinking? If so, I plan on disconnecting the fuel line at tank and pump and see if I can get air through it. If I can what's my next step? Pull fuel tank?
bobschevytrucks.com Ecklers
07-16-17 07:54 AM - Post#2700234
    In response to KansasMike
For sure a restriction somewhere, assuming your gage is accurate. Did your fuel line have a sock filter on the pick up?
KansasMike
Loc: Kansas
Reg: 07-26-15
07-16-17 09:48 AM - Post#2700241
Disconnected fuel line at pump and top of tank. Blew it out with air. Clear. Pulled pick up tube with wire mesh sock on the end from tank and blew it out with air also. Clear. Where do I go from here?
Nitroholic
Nitroholic
Loc: Out West In SoCal
Reg: 05-08-03
07-16-17 09:59 AM - Post#2700242
Did you put on a different gas cap?
'66 C-10 Short Fleetside Big Window
KansasMike
Loc: Kansas
Reg: 07-26-15
07-16-17 11:29 AM - Post#2700249
    In response to Nitroholic
No. Why?
Nitroholic
Nitroholic
Reg: 05-08-03
07-16-17 12:54 PM - Post#2700255
  • KansasMike Said:
No. Why?
The tank needs to be vented and there are vented gas caps and non-vented gas caps.
KansasMike
Loc: Kansas
Reg: 07-26-15
07-16-17 03:29 PM - Post#2700267
Primed carb with a syringe 6 times. Fire...die...fire....die. 6th time she took off and is running great. Confused as to what caused fuel line to run dry. Truck was parked on a pretty good decline before she sputtered to a stop right after I moved her.
Execution time: 0.248 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:01 PM
