Username Post: Radial Tires or not?        (Topic#346030)
ledzepn
Loc: Washington
Reg: 03-17-17
07-14-17 09:20 PM - Post#2700116
I have a stock 54 Chevy 3100. I have heard pros and cons. My thought is that the truck was not built to run radials. I use my truck as being a work truck. Alignment, steering, wheel bearing and loads to name a few. What do you guys think?
bobschevytrucks.com Ecklers Chevy Trucks LMC Trucks
55 Shaker
Loc: north central IL.
Reg: 03-13-06
07-15-17 08:40 AM - Post#2700155
    In response to ledzepn
Got radials 225/75/15 on my 55.2 3100 TF. truck. I've had no issues in 8000 miles.
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
07-19-17 08:24 PM - Post#2700671
    In response to 55 Shaker
Radial tire all the way. What are the cons of the radial tire?
monty56
monty56
Reg: 04-26-04
07-20-17 08:25 AM - Post#2700707
    In response to BigDogSS
IIRC the radials "cause" wheel wander, and feel as though the front end is moving back and forth. I think as long as all the joints are sound (Kingpins, steering knuckles etc.) it shouldn't happen.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
07-20-17 09:50 AM - Post#2700722
    In response to monty56
My experience has been just the opposite. When I had bias tires on my 60 C-10, the truck would tend to follow road irregularities and pull to one side or the other. After I switched to radials, it now tracks pretty much straight.
I realize that all the trucks in this forum have beam axles (if stock), and I don't know if that would make a difference or not.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
08-04-17 06:08 PM - Post#2702870
Hi Ray, you are spot on, radial tires are simply a more stable design.
They don't squirell around as much as bias ply under deflection loads as one set of cords is crossing the other at 90* and this makes them like a continuous flexible"X" brace around the tire. Bias ply tires are just a loop and do not bind each other in the same way.
Cross plys steer according to the road. Radials steer according to the driver.
Cheers kiwi
Edited by Bel Air kiwi on 08-04-17 06:09 PM. Reason for edit: No reason given.
Execution time: 0.285 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:14 PM
