Username Post: wilwood calipers, d8-4, brake issue        (Topic#346026)
300stw
Reg: 01-13-15
07-14-17 05:38 AM - Post#2700053
i did the c3 vette conversion and used the wildwood calipers, d8-4 and a raybestos non power master cylinder,
the brakes always have a drag on them and the front hubs are hot after a 10 mile drive. took the master cylinder off the firewall so the pushrod isn't engaged doesn't release pressure on caliper, break loose a brake line at caliper, pressure bleeds off, wheel spins free,
so do I have a bad master cylinder, does it have an internal 5psi check valve or? when I look in the brake line ports on master cylinder I cant tell if there is a residual valve, do I rebuild master or?
thanks
Edited by 300stw on 07-14-17 05:40 AM. Reason for edit: No reason given.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
07-14-17 06:53 AM - Post#2700062
    In response to 300stw
Try putting a small flat washer on the studs between the master cyl and booster and see if it helps the situation. There may not be any clearance between the booster push rod and the master cyl piston.
300stw
Reg: 01-13-15
07-14-17 08:40 AM - Post#2700070
    In response to aghaga
I pulled the master all the way off the studs to make sure the rod wasn't the problem, also the push rod is adjustable, I even shortened it before I pulled the master off the firewall,,,
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
07-14-17 12:12 PM - Post#2700082
You might have a drum brake prop valve. Try releasing pressure at the master cyl first, then if still dragging, release at prop valve. If that works fit a disc/drum prop valve.
Steve
1966 Caprice 396 496 496mkII TH400
300stw
Reg: 01-13-15
07-17-17 04:43 AM - Post#2700320
    In response to Crusty66
I should have mentioned, don't have a proportioning valve at all, ordered a new master cylinder will see if anything changes,,,
Execution time: 0.384 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:37 AM
