Username Post: Yet another c3 brake swap problem, HELP!        (Topic#346016)
Jonechev
Jonechev
Loc: Cottage Grove,Minnesota. ...
Reg: 05-03-02
07-13-17 06:40 PM - Post#2699999
Between work and family time I have been working on my car when I can to get my brake swap done to the c3 corvette set up I bought a while back. After a fair amount of time and money spent refurbishing everything for this set up I have come to find that my wheels no longer fit!!! Never heard anybody mention this problem with this swap. My rims are 15 inch weld drag lites. With the massive four piston calipers sticking out so far my rims won't clear them. Not sure where to turn from here. Any of you that have made this swap, what kind of rims or back spacing do you run on your car? Would a adapter or spacer work? Not sure where to turn from here. Disheartening to say the least. Summer is slipping away fast and the car hasn't made it out of the garage.
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
07-13-17 07:37 PM - Post#2700016
    In response to Jonechev
Don't despair, this will get figured out.
There were C3's with 15" wheels, but they had 4" backspacing and 1/2" offset, so the next step is to determine how your wheels differ from those specs?
Ryan
65 Impala SS convertible 283 2V with Powerglide and 10 bolt 3.08 open
Build date Dec. 21 '64 Oshawa
impalatom
impalatom
Loc: Iowa
Reg: 03-17-01
07-14-17 06:52 AM - Post#2700055
I did the C3 Corvette front brake swap last year on my 65 impala convertible. I use 15 inch Chevy ralley wheels and they work fine with the C3 brakes.
65 Impala SS convertible 55 Nomad 03 red 'rado 5.3 2wd ext cab.
Jonechev
Jonechev
Reg: 05-03-02
07-16-17 10:07 PM - Post#2700303
    In response to impalatom
Sounds like my problem is just related to the back spacing of my current wheels. After some research I think I am just going to run a little longer wheel stud and a 3/4 inch spacer to gain the clearance I need. Eventually I will change my rims and tires but it's not in the budget at the moment. These wheels always seemed to be a bit too far inside the wheel well to me anyways.
txturbo
Loc: Rosenberg,TX USA
Reg: 07-27-01
09-07-17 02:29 PM - Post#2706950
I've seen it mentioned quite a bit and I think I even have it in the article I wrote about the conversion in the sticky section.
Dan
1969 Camaro SS 396/T400
1966 Impala 283/PG/AC
1966 Impala SS 427/4 Speed
1948 Panel 1 Ton
1963 Cadillac
1940 Ford P/U
1954 Chevy 3100
1955.2 Chevy 3100
1956 Cadillac CDV PINK
1930 Model A hot rod
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
09-15-17 10:39 AM - Post#2707731
Same here. I have 15x6 up front with no issues.
Nitrous is like a hot girl with STD's…You know you wanna hit it, but you’re afraid of the consequences!
1965 Biscayne 2 Door Post: 350,PG,373-posi,C3-DB, PS,PB.
1970 Chevelle Malibu: 53 on 753.
Brian Daniel McClure: 1970-2015. R.I.P. Brother.
Execution time: 1.749 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:36 AM
