Username Post: Radiator fan, 327        (Topic#345974)
Flying_Dodo
Flying_Dodo
Reg: 07-11-17
07-11-17 04:00 PM - Post#2699675
Hey folks, new to the forum.
Just picked up a '68 GMC.
Got a quick question, if you don't mind.
I was under the hood cleaning the idle circuit and noticed the only radiator fan is a small aftermarket electric job.
This can't possibly be enough for a 327, can it??
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
07-11-17 05:05 PM - Post#2699685
    In response to Flying_Dodo
Is it overheating? Does it run cool? What is the diameter of the "small aftermarket fan"? If it were me I wouldn't use anything but a 16 inch Spal puller fan.
Gary
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
07-12-17 05:48 AM - Post#2699739
As long as it's cooling ok and not over heating it should be fine. That being said the name brand plays a big part in how long it lasts.
The cheaper fans don't last long, i have been through two on my Impala so far.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Flying_Dodo
Flying_Dodo
Reg: 07-11-17
07-19-17 10:19 AM - Post#2700603
    In response to Tri5man
Thanks.
It's hitting 215 and staying there, although I can't vouch for instrument reliability or accuracy, someone put those autozone gauges in, and while it says "water temperature", I haven't even tracked down where the sending unit is yet.
This is at idle sitting for a bit and driving 40ish MPH.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
07-19-17 04:04 PM - Post#2700643
For cooling:
Rule of thumb.
Cooling.
1,250 CFM for a 4-cylinder
2,000 CFM for a 6-cylinder
2,500 CFM for a 8-cylinder
A further note is that engines that are 5.0-liter (302 cubic inches) or larger should use an electric fan with 2,800 or more CFM. Obviously, an 800-horsepower engine will need more cooling than a 400-horsepower version regardless of the cylinder-count, but this basic guidance will get you started. And no amount of CFM will keep an engine cool if the radiator is under-sized or if too much of the grille-opening is obstructed. But let's move on, assuming that you have a typical engine in a typical enthusiast's car or 4x4 with a proper radiator.
A few rules of thumb:
Don't use an electric fan as the primary fan on 4-core radiators. It overworks the fan to try to draw air through these extremely restrictive radiators.
It's recommended to have at least 70-percent of the radiator core covered by the fan shroud.
Use puller electric fans (mounted behind the radiator) for primary cooling. A pusher (mounted in front of the radiator) is appropriate as an auxiliary fan.
These general guidelines should address most of the questions and issues you run into when trying to determine which electric fan will fit on your application.
New vehicles run at 210* all day long and are fine.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Flying_Dodo
Flying_Dodo
Reg: 07-11-17
07-26-17 10:39 AM - Post#2701539
    In response to Andy4639
Thanks. I'll keep an eye on the temps.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
07-26-17 04:52 PM - Post#2701577
You could invest in a heat gun from Harbor Frieght as well and see how it's doing.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Flying_Dodo
Flying_Dodo
Reg: 07-11-17
07-27-17 03:52 AM - Post#2701615
No harbour freight in this area.
It was pretty hot out yesterday (about 94), and temp gauge showed 225ish.
I'm probably going to invest in a larger cfm fan.
Execution time: 0.256 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:47 AM
