Username Post: How to add a master switch to our Nu-Crank switches        (Topic#345960)
Nu-Relics
Nu-Relics Power Windows (Site Sponsor)
Nu-Relics
Reg: 05-24-17
07-11-17 05:30 AM - Post#2699581
As many of you know if you are using our Nu-crank switches with your original crank handles the kit comes with individual wiring harnesses for each switch. So if you have to roll down the passenger side or a rear window you would have to reach over to it. The way around this is to add one of our MASTER SWITCH kits to the nu-cranks. This kit will provide an additional switch plus the needed wiring. You can hide the master switch under the dash, seat or in the console or mount it some where that is visible to the driver. We have these with a quad switch for 4 window applications and a single switch for 2 window applications.
Here are some diagrams that show how this is wired up as well as photos of what comes in the kits.
Attachment: Master_Switch_-_Quad_for_Nu-Cranks.jpg (1.78 MB) 11 View(s)
Attachment: Master_Switch_-_Single_for_Nu-Cranks.jpg (1.04 MB) 11 View(s)
Attachment: Nu-Crank_2_Gang_Master..pdf (163.55 KB) 15 View(s)
Attachment: Nu-Crank_4_Gang_Master..pdf (202.69 KB) 15 View(s)
Attachment: Nu-Crank_Single_Master..pdf (163.99 KB) 14 View(s)
Edited by Nu-Relics on 07-12-17 11:04 AM. Reason for edit: No reason given.
Execution time: 0.223 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:55 AM
