Username Post: 1941 windshield divider        (Topic#345920)
honestjerry
honestjerry
Reg: 02-23-08
07-09-17 04:31 PM - Post#2699359
So I have the outer stainless trim piece. Can someone tell me what else I need? Is there an insert that goes in the back or? Pics?
MikeBuller
Loc: Midland, MI
Reg: 07-24-17
07-24-17 06:58 AM - Post#2701173
    In response to honestjerry
I should be able to help you with questions on this topic. I posted several article related to the topic on the VCCA chat site. http://vcca.org/forum/ubbthreads.php/topics/361798...
Unfortunately, the pictures are not currently available that accompany the articles so you can email me if you want me to send them. You can also request my phone number and talk through your questions with me.
Good luck, Mike
P.S. This is my first post so be patient as I learn more about using the site.
07-24-17 08:09 PM - Post#2701294
    In response to MikeBuller
Mike, Welcome to the site. I know you are an invaluable source of info.
jbouchard
Reg: 08-07-12
08-10-17 06:07 PM - Post#2703702
On mine, (41 special deluxe, 4 door) I believe the center metal divider just snapped into place. It snaps into a bracket which is part of the center divider trim from the inside of the car. This is where the screws are that cover the center divider.
On the outside, there are grooves at both the top and the bottom where it rides the outer reveal molding, but all that is holding it is those brackets it snaps into.
When I took mine off initially, I bent it a little bit so it did not fit as snugly as when it was first on.
Here is a link to the rubber portion of the bracket it mounts to on Chevs of the 40s.
https://www.chevsofthe40s.com/detail/9450/Chevrole...
I believe the metal brackets rides this rubber strip...
Judson
Execution time: 0.222 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:42 PM
