Join the Community today
Username Post: Removing spot welds        (Topic#345889)
Ole61
Ole61
Loc: Ohio
Reg: 08-11-16
07-08-17 06:33 AM - Post#2699194
Hello everyone,would like to know if anybody has a trick for spot welds,I bought a spot weld cutter but it likes to scoot around a lot tried to center punch spot weld but that didn't help much any tricks or ideas would be appreciated,I have 111 spot welds to do thanks Ole 61
monty56
monty56
Reg: 04-26-04
07-10-17 08:28 AM - Post#2699446
    In response to Ole61
If you aren't saving the material behind the spot weld use a "Bullet" bit drill bit. I used a small bit to put a dot where the Eastwood spot weld cutter tip would follow.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
07-10-17 06:07 PM - Post#2699532
    In response to monty56
If you aren't saving the top metal, just use a whizz wheel to grind away the top layer. Just go slow at first so you don't grind away the lower layer. You'll get used to doing it pretty quickly. You'll be able to see the layers pretty readily. If you aren't saving the bottom layer, just drill the spot weld out. Spot weld cutters aren't often needed unless you need to save the bottom layer and reuse the top layer for whatever reason. I use Blair cutters. They look like a mini hole saw with a spring loaded centering point. You can change the cutter. It screws onto an arbor and they are double sided. They will do quite a few welds. I usually drill a shallow indent with a 1/8" bit to keep the cutter from walking.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
07-11-17 09:04 AM - Post#2699614
    In response to wagonman100
Ole61
Ole61
Loc: Ohio
Reg: 08-11-16
07-11-17 05:50 PM - Post#2699693
    In response to grumpyvette
Ole61
Ole61
Loc: Ohio
Reg: 08-11-16
07-11-17 05:53 PM - Post#2699694
Thanks for the replys and tips,very good articles grumpy read a few,gonna read the rest of them
Pistol
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
08-16-17 03:29 PM - Post#2704489
I always drill the center of the spot welds with an 1/8 drill and the used http://www.ebay.com/itm/Spot-Weld-Cutter- Drill-Bit... works great for me and I try to gauge my drilling to one layer of sheet metal.
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics
Tom_Kochtanek
Loc: Columbia, Missouri, USA
Reg: 11-19-02
11-26-17 09:34 AM - Post#2715783
    In response to Pistol
A buddy of mine recommended using a plasma cutter set on stun to attack the top of the circle. Here is his wording:
"Use the plasma on the spot welds. Turn it down to stun and draw a circle around the spot weld. It should only penetrate the top panel……then pop it loose with the separator blade. Worked for me."
I haven't tried this myself, I did it the old fashioned way with the tool and a drill...
Execution time: 0.223 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:34 AM
