 Page 2 of 2 <12
Username Post: Borderbum's 67 4 door HT ls build        (Topic#345862)
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
08-25-17 08:05 AM - Post#2705545
    In response to Borderbum.SS
Hi Jeff,
Yes, if you become a supporting member, you'll be able to upload directly from your computer.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
08-26-17 07:20 AM - Post#2705649
If you are at least a silver member you can load directly from your computer....somehow didn't see previous post..my apologies for the duplicate response.
Edited by toro455 on 08-26-17 07:22 AM. Reason for edit: No reason given.
wheelman
wheelman
Loc: Long Island--New York
Reg: 04-14-07
08-26-17 05:19 PM - Post#2705693
The Software doesn't perit, it's not the site administration
1968 Impala Sports Coupe
2004 Jeep Grand Cherokee
Save a Classic - Crush an Import
[url=https://www.facebook.com/greg.leonovich [/url]
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
01-27-18 09:04 AM - Post#2722341
    In response to wheelman
Link
I have started a video blog if you will regarding my 67 4 door Hardtop. Metal work is done, because most reproduction parts are probably made for 65-70 instead of 67 specifically....we had some issues , luckily I have a fabricator that can make quarter panels... sweet! Subscribe and like! I will try to go over 67 specific stuff along with my LS swap LS specific stuff. Its coming together. Another video most likely this weekend!
Jeff
1967 Impala 4dr hardtop
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
01-27-18 08:23 PM - Post#2722389
1967 Impala LS build part 2
Frame stands, motor mount adapters etc...
Jeff
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
02-02-18 10:32 AM - Post#2723080
1967 Impala por-15 clip 1
UV protection * correction lol
Subscribe and like
Jeff
1969 Chevelle
1970 Nova 396 SS
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
02-02-18 01:32 PM - Post#2723102
I watched your videos --> Awesome!!
If your car had a 3-speed automatic in it originally, it was a TH400. The first year for the TH350 was 1969.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
02-03-18 08:08 AM - Post#2723179
    In response to BigDogSS
"If your car had a 3-speed automatic in it originally, it was a TH400..."
To answer whether or not it was originally a TH400 he could take a look at the welded frame bracket for the transmission cross member. The power glide and the TH400 require two different positions. GM added a second welded bracket per side for TH400 cars. At least that's the case for '68 (front position is not used with the TH400 but GM kept the PG bracket on all cars). The front position for the Power Glide is also where the bracket needs to be for the TH350.
So at least for '68 any car which came with a TH400 would have 2 welded brackets per side. Anything which came with the PG had only one per side. I never verified what they did for manual transmission options.
Scott
02-03-18 03:03 PM - Post#2723210
    In response to toro455
All of the manual transmissions (3 speed, 4 speed and OD) use the same mounting position as the PG.
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
02-03-18 04:45 PM - Post#2723214
Ok, i was going by the 350 turbo written on the diveshaft in the trunk. But i am always up for better info lol. Thanks
Jeff
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
02-05-18 07:25 PM - Post#2723474
video 3 of ls 67 Impala build. clip 2 Por-15
NEW video. Thanks for tbe input and subscribe and Like!
Jeff
1969 Chevelle
1970 Nova 396 SS
toro455
toro455
Loc: Western NY
Reg: 06-15-02
02-07-18 09:12 PM - Post#2723711
Well that video hit home for me. I still have a wire, from wire wheeling a frame while under a car, in the knuckle of my right hand. It's been there since around 2002. I was wearing a mask, a hat, long sleeves, safety glasses and nitrile gloves while using a cordless drill. The wire went through the glove. I never even realized it when it happened but later my hand was itching. I could barely see a spot if I pinched it with the other hand but I couldn't remove it myself. The next day I couldn't even see it but it was visible in the x-ray. A hand specialist tried to remove it but it was so close to things and has a slight spiral so he was nervous and finally decided to close it up without removing it.
I should have been using leather gloves but in any case I now use the 3M style sandpaper flapper wheels which have something like the scotch brite material layered between. The heads are expensive but I've had a wire in my knee from a wire wheel, the one still in my hand and a friend even had one which was just above his eye. My apologies for the long explanation but I would recommend re-thinking the wire wheel use.
That was also a good comment you had regarding getting the top of the frame later. On the car I was doing I used a wire bristled brush by hand. I then used an old tooth brush to paint the top portion. Your solution is better but if removing the body isn't in the plan the tooth brush technique worked pretty well. Despite having success with POR I've recently switched to Rust Bullet. They seemed to publish more test type information and their products are UV resistant. For the sticking lid on POR or Rust Bullet a piece of clear plastic wrap under the cap works quite well. I also use a plastic coffee or lemonade mix scoop to ladle the paint into a small plastic container. Scooping it out drastically reduces the amount which gets in the ring of the can. When POR dries it won't stick well at all to plastic cups so you can let it dry and occasionally I've removed a perfect form, of the cup which I was using, out made of paint.
Scott
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
02-10-18 07:28 PM - Post#2723989
Today's progress
Jeff
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
02-10-18 07:48 PM - Post#2723991
Scott
I havent heard anything bad about your stuff, and if I had not done my own research, i would see your point. I guess I have worked with it so long, I haven't looked for others...
As far as the bastardly wires....I have felt the pain... but I did notice...if I bought more expensive wire wheels or cupped suckers for my drill, I didn't see as much flying wires as I did with ones I have bought from Harbor Freight. Those fly apart a lot quicker .. I am enjoying making these videos for several different reasons...
1.The 67 Impala is almost a bastard child as far as parts and new information.
2. It helps me do things better...if I had no videos to do...I would probably cut corners...but the videos hold me to a better standard... I also have worked on my garage a lot more for a better backdrop! Lol
Jeff
1969 Chevelle
1970 Nova 396 SS
toro455
toro455
Loc: Western NY
Reg: 06-15-02
02-10-18 09:02 PM - Post#2724006
Great job with the videos. I like your car as well. I've had a '68 for a long time and it seems like the '67 and '68 are largely over looked.
I think I was buying my wire wheels at Valu Home Center at the time I got the one in the hand. If I were to guess the brand was probably Stanley. I wasn't aware of HF at that time. Those sandpaper flappers work quite well and are worth trying.
Keep up the great work :)!
Scott
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
02-11-18 03:47 PM - Post#2724095
Scott
Thank you, I see myself getting a bit better at the video stuff. A little bit better mind you lol!
Always looking for better ideas or steered in the right direction if I am heading off the edge.
I am starting to see a forward progress now... metalwork is done, so now is the fun stuff. I dont think I will ever work on a car again till the metal work is done... It makes a forward dirrection possible without as many backward steps...and if I find more metal work needing done...I dont have fresh paintwork on it..
Thanks again for the subscriptions, likes and shares! Look forward to more videos. Excited because by using tbe videos...it ensures no cutting corners!
Jeff
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
02-19-18 08:25 PM - Post#2724919
Walk Around part 2
Subscribe and like! Motor is soon! Ordering the new ez car wiring harness this week. Don'teven want to look at the factory wiring!
Jeff
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
02-26-18 09:49 PM - Post#2725778
Another video is up , wiring is next from front to back. part 4.1 Garage Shop projects
Subscribe and like!
Jeff
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
02-28-18 11:09 PM - Post#2726069
https://youtu.be/nTz4N-C6WHE
Motor/ transmission has been purchased. This weekend should be exciting!
Subscribe and like!
Jeff
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
03-04-18 02:08 PM - Post#2726416
Motor arrived
Motor is in...not installed lol waiting on the Holley 202-1
Jeff
1969 Chevelle
1970 Nova 396 SS
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
03-05-18 10:43 AM - Post#2726505
Looking good!
Transmission mounts: For 1967, ALL frames delivered to the assembly plant had the forward transmission mount already installed, which accommodated the following transmissions: standard 3-speed, Muncie 4-Speed, Saginaw 4-Speed and PowerGlide. During assembly, if the car was to receive a TH400 transmission, the SECOND mount was welded onto the frame by assembly line workers, right on the assembly line.
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
03-08-18 08:14 AM - Post#2726859
  • BigDogSS Said:
Looking good!
That is really good information! Hoping my 4l65e crossmember fits... looks like it might by eyeing it...
Got my $400 oil pan..it was from Summit, it came a day early...but to the wrong house, it is scratched up...no gasket, and no stickers from Holley or Summit.....the last 2 don't really float my boat...but you would think after spending $400....that they might give you some extra stuff lol
Jeff
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
03-08-18 08:15 AM - Post#2726860
Thank you Bigdogss. I am liking the feedback i get with the videos...they keep me on task. I appreciate your help
Jeff
1969 Chevelle
1970 Nova 396 SS
toro455
toro455
Loc: Western NY
Reg: 06-15-02
03-08-18 09:24 AM - Post#2726870
Jeff,
I was selling some of the transmission frame brackets. In doing so I did some research regarding mounting positions. This is what I found:
The position for the TH400 frame brackets will also allow the ability to use the TH200R4 (TH200-4R). Moving the position back further should also allow the 4L80E. The correct position for the TH700-R4 is only ¾” different than the position for the TH350 so you cannot add a bracket for the TH700 R4 without removing the existing bracket as it would conflict with the existing TH350 bracket which all cars should have.
Face of Bell housing to center of mounting position:
PG and TH200 and TH350 >> 22 ¼”
TH400 and TH200-4R >> 27 15/16”
4L80E >> 30 3/8”
I did not look into the 4L65E but I thought they were based on the TH700R4.
The interesting thing with your case is the Kwhizz motor mount adapters shift the motor so he may have done this with a particular transmission in mind. I don't recall. Does the kwhizz bracket place the bellhousing surface in the same position as the original powerplant?
I never realized what BigDogSS wrote regarding the extra brackets. I found that to be rather unique. It would also mean that GM probably did have a right and left hand PN used internally for that loose bracket. I would be interesting to know what those PNs were. I was advertising them by description/application only.
"65-66-67-68-69-70-Impala -Biscayne-ss-Transmission -crossmember-mount-Bracke ts"
Scott
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
03-08-18 06:19 PM - Post#2726926
I haven't had the motor and trans far enough down to be able to tell you about the bellhousing.. I did get the holley 202-1 oil pan...it arrived a little scratched up....for $400 i wouldn't expect that...it came from summit.
Jeff
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
03-08-18 06:20 PM - Post#2726927
I Should know a lot by the end of the weekend.
Jeff
1969 Chevelle
1970 Nova 396 SS
Borderbum.SS
Loc: OZARK MO.
Reg: 03-30-17
03-12-18 12:59 PM - Post#2727342
Motor in car with Holley 202-1 pan
Motor is in! Holley ls 202-1 Oil pan used.
Jeff
1969 Chevelle
1970 Nova 396 SS
 Page 2 of 2 <12
Execution time: 2.126 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:02 AM
