Username Post: Fuel gauge fluctuations        (Topic#345824)
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
07-04-17 07:27 PM - Post#2698758
I have a '57 Chevy that has an Auto Meter fuel gauge. I have a Tanks EFI fuel tank with an sender that is rated at the proper resistance for the gauge. It works fine until I turn on the headlights, then drops; for example if it was reading just over half a tank, it drops to below 1/4 tank. If I turn the headlights off, it goes back to the previous reading. The tank is grounded to the frame and the headlights are wired through relays as they were pretty dim and now are bright. Any ideas and help will be appreciated. Larry
Edited by 5Larry7 on 07-04-17 07:36 PM. Reason for edit: No reason given.
07-05-17 11:36 AM - Post#2698837
    In response to 5Larry7
Rotate the headlight switch knob so as to turn off the cluster lighting. Does this make any difference in how the gauge reads?
07-05-17 04:38 PM - Post#2698866
Check the ground wire on the gauge at both ends.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
07-05-17 08:46 PM - Post#2698907
    In response to acardon
Quote: Rotate the headlight switch knob so as to turn off the cluster lighting. Does this make any difference in how the gauge reads?
I will try both of these suggestions and let you know the resutls. Thanks
Edited by 5Larry7 on 07-05-17 08:47 PM. Reason for edit: No reason given.
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
07-05-17 10:23 PM - Post#2698911
Do you have the battery grounded to the frame also? Everything else is grounded through the body. Try a long temporary jumper wire directly from the tank to the battery negative and check again.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
07-06-17 12:56 PM - Post#2698973
I tried this, (headlights on), and the fuel quantity does in fact change when I rotate the headlight switch. Full clockwise increases the amount, counter clockwise reduces it. Full clockwise on the switch does not bring the quantity up to the level as when the headlights are off. Thanks for the tip. I will double check the grounds on the gauge.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
07-06-17 12:59 PM - Post#2698974
    In response to WagonMan
Yes, I have lots of grounds; battery to engine, battery to frame, engine to frame, frame to body and etc. But I will pull the gauge module and see how I grounded the fuel gauge, it has been long enough I do not remember. Thanks for the tip.
monty56
monty56
Reg: 04-26-04
07-07-17 07:19 AM - Post#2699083
The ground for the fuel gauge is at the tank. Check to see where you picked up the "hot" 12v from. Almost seems like you tapped into the "dash lights" by mistake.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
07-07-17 12:29 PM - Post#2699107
    In response to monty56
It's an Autometer aftermarket gauge that requires a ground. The gauge does not ground to the dash like a stock gauge.
monty56
monty56
Reg: 04-26-04
07-08-17 09:26 AM - Post#2699208
I have an autometer gauge in my truck but didn't know it grounded separately. It is part of the whole gauge cluster.
Monty
Monty's 56 Truck
Avatar is my Truck
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
07-12-17 02:15 PM - Post#2699807
Update: I connected an additional ground wire to the mounting bracket for the gauge as per Auto Meter and that seems to have cured the problem.
Execution time: 0.269 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:18 AM
