Username Post: 1972 cheyenne super factory air        (Topic#345657)
hinges56
hinges56
Loc: Canyon Lake ,Ca.
Reg: 06-01-08
06-26-17 04:08 PM - Post#2697599
My air conditioning has been in boxes for about 15 years now due to an accident. (I rear ended an suv) It smashed the condenser, receiver/dryer and and pushed the radiator into the compressor clutch. I'm gonna put a new compressor, dryer and condenser for sure but what about everything else like the poa, hoses, expansion valve and evaporator? Do you think anything is salvageable since it's been open to the air all this time? Where is the best place to buy A/C parts? I see where an AC 10 valve compressor is available. Is this what I should be looking for? Thanks for the help. Scott
Ecklers
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
06-26-17 04:53 PM - Post#2697604
    In response to hinges56
I have done several reusing most parts except the condenser or dryer. Hoses should be inspected and blown out with inert gas, if deemed good. O rings need to be replaced, the poa valve can be cleaned and tested. The evaporator can be cleaned and tested.
My biggest failures have been the compressors failing after a few years, (leaking).
My 66 Impala system has been working well since 1997 but that is a record for me!
The service manual has an excellant section on the AC systems and will be very helpful to you.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
06-27-17 03:50 AM - Post#2697644
Unless you are looking at a 100 points correct build I would look really hard at swapping everything out that you can.
Hoses are cheap and you can have them cut to fit your needs. The POA valve can be swapped out for a orifice tube and accumulator and works great. Mine does 38* on 95* days all day long.
Attachment: DSCF2645.jpg (93.51 KB) 259 View(s)
Late model AC
Attachment: DSCF2643.jpg (99.63 KB) 263 View(s)
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
JimKshortstep4x4
JimKshortstep4x4
06-27-17 05:09 PM - Post#2697740
    In response to Andy4639
I like the original systems since those are most familiar and I was trying to answer his question on salvagable parts. The old systems work for me in the climate that I live in and is not used for any show points as this truck is a driver. Warmer climates such as SC may not get by as I am able to.
Here is a picture of one of my original systems.
Attachment: Kurt__s_AC.jpg (89.31 KB) 270 View(s)
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
06-28-17 03:46 AM - Post#2697832
Wasn't meaning to cut your reply Jim.
I was just trying to give the OP some options. Hoses can be reused but you don't know how they will hold up after being took off a 40 year old truck and what kind of environment they have been sitting in. I wouldn't trust them, that's just me though. You may get years out of them and then again you may get a few hrs, days who knows.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
JimKshortstep4x4
JimKshortstep4x4
06-28-17 04:25 PM - Post#2697910
My experience with hoses has been good but in the case of the 72 Suburban, I replaced the front to rear hoses with new hoses since replaceing them is such a project!
Attachment: Craig__s_Burb_at_Pentwater.jpg (592.55 KB) 263 View(s)
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
06-28-17 04:42 PM - Post#2697911
That is a nice Suburban sir! I would like to find one one day and have it for family trips instead of a new one. I like my 08 Tahoe but a 71-72 Suburban would be just as nice I think.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
06-28-17 07:00 PM - Post#2697946
X2. Very nice truck. No AC in my truck but if I did I would probably drive it a more.
71 Chevelle BBC powered
2010 GMC Sierra crew cab 4X4
JimKshortstep4x4
JimKshortstep4x4
06-29-17 04:37 PM - Post#2698058
    In response to LUVmachine
Thanks! The Suburban turned out nice and it is fun to drive. It took my sons and I 8 years to restore and I will never attempt another one!
We take it to the camp grounds for picnics with my daughter in the summer and it gets a lot of attention!
hinges56
hinges56
Reg: 06-01-08
06-30-17 02:16 AM - Post#2698114
Nice looking system, Andy. If I went that way, would I have to have a serpentine belt system like yours. What compressor is that?
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
06-30-17 06:50 AM - Post#2698125
No,
this was just after the LS motor install. Here it is with v-belts.
It's a sanerson compressor I ordered the kit from Classic air.
Attachment: Motor2.jpg (83.91 KB) 268 View(s)
Attachment: IMG_1672.JPG (158.46 KB) 264 View(s)
Attachment: IMG_3740.JPG (166.18 KB) 272 View(s)
Truck on the cover of Classic air groups cataloge
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Ecklers
Execution time: 0.189 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:07 AM
