Join the Community today
Username Post: Welding backer        (Topic#345586)
Ole61
Ole61
Loc: Ohio
Reg: 08-11-16
06-22-17 02:44 PM - Post#2697081
Hi,I was wondering if anyone uses or has used the magnetic copper welding backers,I'm doing sheet metal work on 61 belair and need every advantage I can thanks
06-22-17 06:50 PM - Post#2697121
    In response to Ole61
I've never used one but it should work well. The magnet will hold the piece in place and the weld won't stick to the copper and act as a heat sink. I personally don't use any backers, I just weld up holes without any.
65_Impala
Reg: 12-29-02
06-23-17 03:10 PM - Post#2697213
If the pieces butt together tight you shouldn't need a backer.
I've had times where I had a bit of a hole to fill. I tried a piece of flattened copper pipe and I managed to weld it to the car. A piece of 1/4" copper bar stock worked OK though.
Ole61
Ole61
Loc: Ohio
Reg: 08-11-16
06-23-17 05:48 PM - Post#2697237
    In response to wagonman100
Wagonman thanks for the reply,the magnet and copper plate would work but it has to be a pretty flat surface took a ride to Eastwood and checked them out if surface not flat leaves space between copper and metal
Ole61
Ole61
Loc: Ohio
Reg: 08-11-16
06-23-17 05:54 PM - Post#2697239
    In response to 65_Impala
Thanks for reply 65 impala,is it better to have a tight fit or slight gap in piece ,I found some thin brass at work gonna try
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
06-23-17 08:14 PM - Post#2697255
If I'm welding holes, I get small slugs from washer bins that you can find in some of the older hardware stores. You can find them in the bottom of the bin. You may have to file the hole just slightly larger to get the "plug" to fall snugly into place. Tack, grind, and repeat!
1951 Fleetline
SteveW
Loc: Shreveport
Reg: 04-24-02
06-24-17 01:12 PM - Post#2697323
Flat "Ceramic weld backing" works great you can find it on ebay. It has metal tape on both sides of the ceramic to hold it in place. Great for back up. Leaves the weld clean on back side. Lots better than copper. Just get flat Ceramic. Shop around some places a lot cheaper than others. Watch video to end and see back side of plate.
https://www.youtube.com/watch?v=2k0Sj5m1uTE
You can use it with any type of welding ,Stick,Mig or Tig. When welding Stainless it wont sugar on back side.
65_Impala
Reg: 12-29-02
06-24-17 08:34 PM - Post#2697358
MIG welder? probably a slight gap but very small. I find touching or almost touching works decent for body steel and if you're fairly new at it then weld much hotter and faster then you'd expect to works best. Get it right and not much grinding is required to make the joint flat. I started welding at 2 on my welder and first thought it was good but now weld at about 4.
If it's a TIG welder then it pretty much has to touch. You'll have a tough time bridging any gaps. I haven't done much TIG yet, but I have welded butt splices with no filler and no grinding required. It's softer and it hammers to relieve the welding shrinkage much easier.
Ole61
Ole61
Loc: Ohio
Reg: 08-11-16
06-25-17 07:18 AM - Post#2697412
Thanks for all the info,might welding with miller cricket xl 65impala
06-26-17 03:57 PM - Post#2697607
A piece of copper, any form, works for welding a hole. I use a piece of copper tube about 8" long. I beat 4" of it flat with a hammer, then bend it 45 degrees at the transition from flat to tube. The tube ends up being a nice handle.
As said, once the hole gets big enough, welding a round disc in the hole is a better way. I'd say that's somewhere around a 3/8" hole.
The copper tube works great if you can position it with your non-welding hand on the back side. Recently I've seen some magnetic holders that hold a piece of copper over a hole for welding. Eastwood may have something, or you can make your own using a dial indicator magnetic holder. This would work great on a big panel like a quarter panel or firewall.
Execution time: 0.231 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:22 PM
