Username Post: Caprice - Rear Park Assist Sensor Not Working - No Error Code        (Topic#345514)
HyperEscape
Reg: 06-19-17
06-19-17 08:07 AM - Post#2696524
Hello,
The park assist on my caprice 2007 has stopped working. The rear park assist system engages when I put the car in reverse gear and the LCD display shows the distance (RAG lights) with beeping sensor . However I have noticed for past few days or so it has stopped working, I am not able to pinpoint the reason why and how to fix it.
1. I got some repair service done to my engine timing belt for which engine block head cover was opened, but I doubt anything over there would have disturbed the park assist, is it so. ?
2. Along with park assist, I noticed that my rear brake lights are not glowing high beam red when pressing the pedal and stay lit at normal intensity. I got it checked with a local electrician and he concluded that brake pedal sensor has gone bad and needs to be replaced. Could this be somehow linked with the park assist system.
I am not receiving any orange check engine light on my dashboard. I have the bluetooth OBD II adapter which I am using with Android (Torque app), however a scanning shows no error codes in the buffer, I am not sure even if brake pedal or park assist systems malfunctions, would it throw an error code or not.
As of now clueless as how to get it fixed.
Thanks for your patience to appreciate any possible guidance for the solution.
65_Impala
Reg: 12-29-02
06-19-17 06:48 PM - Post#2696648
    In response to HyperEscape
The Torque app only does engine codes (and maybe antilock brake codes) so it won't do other body system codes.
The brake light issue could be related.
HyperEscape
Reg: 06-19-17
06-20-17 02:49 AM - Post#2696695
    In response to 65_Impala
Thats an information to know. So how and which readers do read all body codes. I am sure they must be in the professional series.
Do all sensors show body codes if malfunctioning.
Thanks.
65_Impala
Reg: 12-29-02
06-21-17 09:55 AM - Post#2696895
Yes, you probably have to get into a TechII type system to read other codes.
No, not all sensors or circuits in a vehicle will throw a code.
06-22-17 07:56 PM - Post#2697124
The brake lights not working should not affect the park sensors. See what circuit the sensors are on in your owner's manual and check that fuse. Also, is there a switch to turn off the park assist? Most vehicles have one and yours may have gotten accidentally shut off.
Execution time: 0.395 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:29 AM
