LMC Truck
Username Post: 02 blazer horrible fuel mileage        (Topic#345510)
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
06-18-17 06:35 PM - Post#2696451
My son's 4.3 has excessive fuel consumption. The codes said lean mixture both banks. It has since not produced the codes since clearing them but it literally drinks fuel.
Any ideas where to start?
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
LMC Trucks
SleeperSS
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
06-18-17 07:41 PM - Post#2696461
    In response to Original58
A couple of things. I'm going thru this with my SS. No codes, but I put the scanner on it anyway. Turns out my pcm lost its mind and was running 22* retarded. I put a spare pcm in it and like magic advance was 20-30* advanced depending how far my foot was in it. Did a 252 mile road trip yesterday and mpg went from 17-18 to 20.5. How's the exhaust smell? Mine will make your eyes water so it's still way rich. I have a new fpr coming Tuesday and I expect my mpg to go up to where it used to be...23-24 mpg. I'm very anal when it comes to calculating mpg. I use the same pump, fill it to the very top before and after a trip.
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
Senior Chevytalk Moderator
06-19-17 04:04 AM - Post#2696493
    In response to SleeperSS
How does power feel? Is the cat still original?
What do spark plugs look like? Dirty air filter? Dirty MAF sensor? Check for loose hoses on vacuum lines and air intake. When filling up, does fuel gallons equal dial readings?
models916
Loc: Addison, IL
Reg: 05-28-10
06-19-17 07:47 AM - Post#2696535
My 2004 only runs correct on an AC deco MAF. I had a while back replaced it with a Delphi and got bad fuel milage and lean condition at high RPM. MAF should be your first look. It is the first item the PCM looks to for setting ratio.
Original58
Original58
Reg: 10-30-13
06-19-17 09:06 AM - Post#2696544
    In response to models916
I cleaned the maf, new air filter. Plugs changed last fall by GM. What a pain to get at the 1 plug. Hardly used since last November.
No other codes show up and I'm trying to not randomly change parts.
Jeff
Original58
Original58
Reg: 10-30-13
06-19-17 09:09 AM - Post#2696546
How would I go about testing the maf?
Also trying to get the fuel filter off but the threaded end wont budge and there's not a lot of room for my fat fingers .
models916
Loc: Addison, IL
Reg: 05-28-10
06-20-17 03:39 AM - Post#2696705
Not the perfect test, but if the vehicle starts with the MAF unplugged, it's probably not working and the engine is running on a limp mode.
06-20-17 04:18 AM - Post#2696708
Cleaning an MAF sensor: http://easyautodiagnostic s.com/gm/4.3L-5.0L-5.7L/h...
MAF testing: http://easyautodiagnostic s.com/gm/4.3L-5.0L-5.7L/h...
Original58
Original58
Reg: 10-30-13
06-20-17 05:17 AM - Post#2696712
Thanks guys. I'll try this today.
Jeff
LMC Trucks
Execution time: 0.215 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:48 PM
