Username Post: 2004 Blazer P0200 code        (Topic#345502)
Kyle700
Reg: 06-13-17
06-18-17 01:34 PM - Post#2696406
I just put everything back together after installing a intake manifold gasket, now it idles rough and giving me a P0200 (open injector circuit) code.
Has anyone else chase this one down? Where do I start?
Kyle700
Reg: 06-13-17
06-18-17 03:48 PM - Post#2696417
    In response to Kyle700
Is it possible to idle rough and get this code if the distributor is off by one tooth? Didn't have the problem before the tear down, I did overheat and have to be towed home...
06-18-17 04:37 PM - Post#2696420
Sounds like a bad connector to one injector, based on the code and symptoms.
Kyle700
Reg: 06-13-17
06-18-17 04:42 PM - Post#2696421
I can't find injector connections, the research I have done talks about the "injector spider." I rechecked the large injector plug on the top on the firewall side on the throttle body
06-18-17 06:59 PM - Post#2696444
Correct, that is a Vortec injection system. Make sure you have good connections at the junction for starters, the code points to one open injector, if you let it run some you should get a p0300 code, this may pinpoint the suspect injector. Careful not to over heat the cat though.
Kyle700
Reg: 06-13-17
06-19-17 10:52 AM - Post#2696551
I let it run a bit and it came back with a P0303...#3 cylinder misfire
06-19-17 01:39 PM - Post#2696578
Ok, so there is the issue, look at the wiring for that circuit.
Kyle700
Reg: 06-13-17
06-19-17 11:01 PM - Post#2696682
I cleaned and secured the injector plug and checked the #3 spark plug wire at the dist. What else is there to check? Also, what is the white clip that connects to the injector plug, just to secure the plug?
06-20-17 03:25 AM - Post#2696698
The code is telling you you have an open circuit in #3 injector, check the the injector with an ohm meter.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
06-20-17 04:09 AM - Post#2696700
Did you unplug the injector harness and look down in the intake side? You may have bent one of the pins on the connector, it can happen.
Kyle700
Reg: 06-13-17
06-20-17 08:55 AM - Post#2696735
    In response to junkman104
Yes, when I cleaned and made sure the connection was good.
Execution time: 0.448 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:15 PM
