Join the Community today
Username Post: Chevy Equinox 75 miles on it. Why does the ignition key get hot when I remo        (Topic#345477)
Katiefran
Reg: 06-17-17
06-17-17 08:17 AM - Post#2696230
Chevy Equinox 75 miles on it. Why does the ignition key get hot when I remove it???
Don57
Don57
Loc: Illinois
Reg: 04-28-00
06-17-17 12:30 PM - Post#2696260
    In response to Katiefran
GM had that problem with some models about 10 years ago. It required replacing the ignition switch assembly. But I assume yours is a new vehicle. Check with your dealer.
WagonCrazy
WagonCrazy
Reg: 06-07-05
06-17-17 07:59 PM - Post#2696308
    In response to Don57
Electrical resistance makes heat...so it seems like your ignition switch has some resistance between circuits inside if it.
Definately a dealer repair under warranty.
WagonCrazy
WagonCrazy
Reg: 06-07-05
06-17-17 08:00 PM - Post#2696309
    In response to WagonCrazy
Wait a minute...you said the key gets hot after you remove it? The key....gets hot.....after you remove it?
Is it a fob type key, with a battery within?
Still think this is a dealer warranty issue.
Execution time: 0.158 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:12 AM
