Username Post: Transmission leak        (Topic#345446)
Airlifter
Airlifter
Reg: 06-07-15
06-15-17 03:15 AM - Post#2695984
Took a short drive yesterday and parked the car in front of the garage when I returned. When I moved the car into the garage later I found a large puddle of transmission fluid where it had been parked. Well, at least it is still under warranty.
1951 styline deluxe sport coupe w/54 engine & powerglide
Fin
Fin
Loc: Finland, Northern Europe
Reg: 09-27-10
06-15-17 06:25 AM - Post#2695998
    In response to Airlifter
Long warranties you guys have there, over 60 years!!
210 Handyman -54, 235 with Isky Racing cam. Slightly lowered wannabe rat.
To be continued...
For sunny days, Alfa Romeo Spider Lusso.
Airlifter
Airlifter
Reg: 06-07-15
06-15-17 10:55 AM - Post#2696027
    In response to Fin
I wish! Transmission was rebuilt this past winter.
Fin
Fin
Reg: 09-27-10
06-15-17 11:47 AM - Post#2696032
Yes, I know. I´ve read yor earlier posts but I just had to
To be continued...
Airlifter
Airlifter
Reg: 06-07-15
06-15-17 06:10 PM - Post#2696084
    In response to Fin
I understand. Wish I had thought of it.
Hugh in NC
Hugh in NC
Loc: In my Recliner Rockingham...
Reg: 08-01-12
06-17-17 04:12 PM - Post#2696274
Instead of a leak, you could have the famous powerglide burp. The first time mine did the burp I didn't know what had happened.
Hugh
Miss Daisy - 1951 Styleline Deluxe 2 Door Sedan
Airlifter
Airlifter
Reg: 06-07-15
06-17-17 05:32 PM - Post#2696280
    In response to Hugh in NC
Have not heard of that. Does it happen often?
Toqwik
Toqwik
Loc: Middleburg, FL
Reg: 05-14-17
06-17-17 08:05 PM - Post#2696301
I had a similar problem with a fresh turbo 350 I put in a 41 Chevy I built. Turned out mud dobbers built a nest in the vent tube. Check the vent for a blockage. Good luck with your project.
Toqwik
Contentment is the smother of invention
Hugh in NC
Hugh in NC
Reg: 08-01-12
06-18-17 05:26 AM - Post#2696332
My powerglide has burped transmission fluid out the fill tube 2 or 3 times over a 5 year period. There is information on this site if you can find it. Clean up the trans as best you can. If there is no further evidence of leaks you will know it was the burp.
Hugh
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
06-18-17 06:18 AM - Post#2696347
Do not start it in Park. It will burp. In fact do not let it run in Park, the pump does not run while in park.
I always start mine in neutral,
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
06-18-17 06:24 PM - Post#2696433
    In response to Rustchips
Hi Cleon, Is that the 50-52 Glide or the 53-4 as well.?
Cheers Kiwi
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
06-19-17 05:29 AM - Post#2696499
    In response to Bel Air kiwi
I think all 2 speed Powerglide oil pumps will not pump with the selector in park.
Cleon
1928 Chevy Coupe
1970 El Camino
Airlifter
Airlifter
Reg: 06-07-15
06-19-17 11:45 AM - Post#2696559
It is at the shop now. When they got it on the rack I saw a couple leaks. One from a cooler line and one the shifter rod. There might be more.
Thanks for the info on starting in park. I don't think I ever heard that
Toqwik
Toqwik
Loc: Middleburg, FL
Reg: 05-14-17
06-19-17 06:24 PM - Post#2696645
I never knew that, some good information, thanks!
Execution time: 3.238 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:49 AM
