Username Post: wiring/no spark issues        (Topic#345416)
mynew72
Reg: 06-13-17
06-13-17 05:44 PM - Post#2695845
i have a 2010 350 crate motor in my 72 chevy. it has new comp cams, new distributor, new coil,new rotor and i have no sprk. please advice!! also this site rocks you guys are really knowledgeable and supportive. my girlfriend just bought a kia and the motor blew..guess what no kia forums except how aweful they are
bobschevytrucks.com Ecklers
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
06-15-17 12:17 PM - Post#2696041
    In response to mynew72
Isn't there a module you have to buy/add to fire the LS ignition system/coils?
I know there is if you are staying EFI & the PCM has to be reprogrammed to remove the anti-theft passlock key system...
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
06-15-17 04:09 PM - Post#2696068
    In response to Bad Bowtie
I am assuming it's a standard 350 with a carb. Run a #10 wire to the b+ terminal on the distributor to the fuse box terminal labeled ign (if memory serves me correctly).
The factory wiring is not setup for a HEI and depending on who has had their hands in it over the years you might be tied into it where you are not getting the full 12-14 volts. Start with the basics and verify the spark is actually the problem.
71 Chevelle BBC powered
2010 GMC Sierra crew cab 4X4
mynew72
Reg: 06-13-17
06-19-17 03:41 PM - Post#2696604
    In response to LUVmachine
i am also having this problem on a 72 chevy 350. i pit the old distributor on the benh vice and hooked up the battery. everything works fine on the bench.i re installed in the truck and no spark. i rewired just like you said bat+ to fuse box and yet nothing. i even went as far as to chnge the ignition swith thinking maybe it went bad and wast send signal to coil. i am officially stumped!
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
06-19-17 05:23 PM - Post#2696632
Welcome to Chevy Talk from West Michigan!
I am not clear on how you are testing a distributor on the bench. Also, do you have a full 12 volts at the distributor with the key on? Hooking up the distributor as suggested should give you full 12 volts at the distributor.
Good luck,
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
06-19-17 09:06 PM - Post#2696667
It would be easy enough to test a points-type distributor off the engine if you are electrically competent. An electronic dist would be a whole other story.
The OP said he tested the "old" dist, so I assume it had points. He didn't say exactly HOW he tested it though. IMO, the best plan of action would be to ask him.
JimKshortstep4x4
JimKshortstep4x4
06-20-17 12:07 PM - Post#2696775
I am familiar with using an ohm meter to test electrical components but my preference is to test distributors, (points or HEI) with my distributor machine up to 5,000 rpm with it actually firing.
Attachment: P5260001.JPG (657.97 KB) 12 View(s)
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
06-20-17 12:18 PM - Post#2696776
To the op just to be clear. I assume it was an HEI distributor. Most car and truck guys will almost always have a spare module laying around somewhere. If you can find an extra module try swapping it out and see if that cures the problem. Don't forget the heat sink compound or it will burn up.
My next suggestion is to try another coil and don't forget to put the ground strap back in.
This might be a stupid question but is there any chance you could have the battery wire on the tach terminal? Also did you verify with a test light or meter that the terminal you tied onto in the fuse panel was actually hot with the key in the run and start position?
Execution time: 0.381 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:20 PM
