Username Post: Rate this setup for my '56        (Topic#345402)
regan56
regan56
Loc: Regina SK Canada, eh!!
Reg: 12-09-02
06-13-17 07:09 AM - Post#2695776
327 with a mild-to-mid level comp cam (cant recall #), 750CFM Q-jet, TH350, 3.08 gears.
this is what i've got gathered up for the drive / power train. Looking for a nice street truck feel.
What do you think?
Also, any suggestions on an HEI distributor? (AC-R44 plugs)
2014 GMC Sierra All-Terrain Sonoma Red Crew
1956 GMC StepSide - in progress
Edited by regan56 on 06-13-17 07:10 AM. Reason for edit: No reason given.
06-13-17 07:30 AM - Post#2695780
    In response to regan56
With a 2.52 low and a 3.08 rear, it's not going to be very peppy on take off and a 750 carb is pretty large for a 327. A 700R4 has a a 1st gear of 3.06 and the OD would allow a 3.36 or more rear abd keep the cruising RPM down.
regan56
regan56
Reg: 12-09-02
06-13-17 08:37 AM - Post#2695795
    In response to acardon
ya i had picked up the rear end for basically nothing without knowing what was inside, so when i checked it at home i was kinda thinking the same. The carb..again free but is it too large?
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
06-13-17 01:43 PM - Post#2695820
"Qjet" - It's a Rochester Quadrajet. The air valve and the array of fuel circuits designed cover so many part throttle conditions that no other carb can do, tells me it will work great - if the correct jets and needles can be found...
I have a low compression 327 in a 1970 c20. It's OK but I'm thinking about getting something with more torque (bigger), instead of trying to make a basically high revving engine behave as a truck engine.
I agree a th700 is a better match with the rear end.
There are those wanting a 327, rather than a 350 in Chevelles, Camaros and Novas, so I would consider selling the 327, then get at least a 350. A vortec 350 and find the best cam for your needs and the final gear you end up with.
A big body GM HEI is the way to go. An original GM, rather than the aftermarket. I hear the quality of aftermarkets are varying. The OEM works really well - even after many miles.
http://www.youtube.com/watch?v=SXn2QVipK2o&a mp;fea...
Edited by Impala65SS on 06-13-17 01:47 PM. Reason for edit: No reason given.
regan56
regan56
Reg: 12-09-02
06-13-17 02:46 PM - Post#2695827
    In response to Impala65SS
ya..i wont be selling the 327..i just finished rebuilding it. id be divorced.
teh TH350 i have needs to be looked at as i cant recall what condition it was in when i bought it a few years ago, so there is an option to be swapped out.
i guess i have two options
1. different geared rear end - 3.31/3.44/3.55 or whatever
2. different tranny - 700R4 say
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-13-17 05:16 PM - Post#2695842
while a 2.87:1-3.08:1 rear gear if far from ideal for a performance application,and yes displacement does mater,as does the transmission gearing and/or converter stall speed, a great deal of the throttle response and the effect your carbs flow rate has on the torque curve,will be related too the cam timing, the engines compression ratio, the intake manifold design, and how your throttle is employed (IE an experienced driver can do a great deal to influence the way the car responds, an experienced driver that knows his cars characteristics can do a good deal to maximize acceleration.)yes you can improve acceleration with a higher numerically rear differential ratio like a 3.73:1-4.11:1 gear especially with an over drive transmission, and a 2600 rpm-3200 rpm stall converter, but its the driver who controls a good deal of the cars ability to put power effectively to the pavement. and the ability to match the cam timing, intake design and properly tune the combo you have is critical. a 327 has a fairly short stroke of 3.25" and that potentially allows it to be matched to high flow rate cylinder heads and a solid lifter cam that will allow the engine to operate in the 7000rpm plus range
Edited by grumpyvette on 06-13-17 05:37 PM. Reason for edit: No reason given.
models916 67
Loc: Addison, IL
Reg: 05-28-10
06-14-17 07:01 AM - Post#2695898
    In response to grumpyvette
I would go with a 3:40-3:70 rear gear with the OD.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-14-17 07:16 AM - Post#2695901
    In response to models916
all it takes is a tiny bit of research and some math to calculate the ideal rear differential gearing, tires size etc. and transmission gear ratios, and you can certainly select the correct torque converter stall speed if you have a dyno graph of your engines power curve without much difficulty, an hour or so spent in reading and research will provide you with a great deal better performance from most cars.
and a couple days worth of research and doing some math on all of the power trains component parts will provide you with a wealth of info that can prevent you from making costly mistakes.
regan56
regan56
Reg: 12-09-02
06-14-17 07:27 AM - Post#2695903
teh 327 has a stock intake and with heads from a 350. it ran like that before i got it and i wasn't game to change that part, maybe later if i feel the need.
i see alot of the responses i get are regarding performance (maybe partly because thats the forum i'm in) but i'm not looking for a hard shooter off the green lights that burns through all gears. i do want it to be able to handle itself and not take 3 seconds to take off from a dead stop though. i don't disagree that a different gear ratio and / or a different trans would be "better" but is it necessary?
maybe a street truck isnt the proper terminology then..think of it as a Saturday night cruiser that gets some daily use here and there, but isnt an old dog, but maybe a middle aged dog that knows some tricks but knows better than to show-off.
oh and i do know how to handle the throttle to make things do what i need.
regan56
regan56
Reg: 12-09-02
10-25-17 10:51 AM - Post#2712119
..well i took the TH350 to a trans shop for a quick review before i stuffed new parts back in it. pump is shot, case worn, sun shell worn/warped, all the frictions were wasted (that i already knew) long story short.,.its garbage. not the end of the world as it was a BOP trans that i got for basically free.
looking for a 700R4 now...
Execution time: 0.212 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:34 AM
