Username Post: Factory '93 alloy wheels on '72 disc brakes        (Topic#345396)
southwoods
Reg: 06-12-17
06-12-17 06:55 PM - Post#2695733
anyone with experience installing 1993 chevrolet 4x4 factory aluminum 16" wheels on 1972 K5 blazer (front disc, of course). i had the centers machined out using original 15'' factory steel wheel as pattern, plus machined out extra 1/64".
rear wheel installed with no problem but something(probably original '72 caliper) is keeping fronts from fitting.
does anyone know if there is a slimmer/thinner caliper that will work? 2 pins/bolts that hold calipers in position are 7" center to center on originals.
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
06-13-17 07:28 AM - Post#2695793
    In response to southwoods
Welcome to Chevy Talk from West Michigan!
Hopefully you get the information that you need. I don't know of a caliper like you are looking for but I wonder if CPP can help you?
They are a Chevy Talk sponsor and there is a forum
on Chevy Talk where you may want to post the question.
Here is a link to CPP, http://www.classicperform.com/
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
southwoods
Reg: 06-12-17
06-13-17 08:26 AM - Post#2695801
thanks, jim.
i'll try that site
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
06-13-17 04:45 PM - Post#2695846
Maybe I'm missing something here but I have 15" wheels on my truck with out any clearance issues. On my old 78 c10 I put 15" rally wheels on it and had to use a thin spacer on the front. Have you tried using a set of the thin spacers to see if that helps?
71 Chevelle BBC powered
2010 GMC Sierra crew cab 4X4
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
06-22-17 06:15 PM - Post#2697111
    In response to LUVmachine
I am "Assuming" that Luv is correct...the rim you are using probably has more (or less) off-set and a sspacer might do it for you.
How much room do you need?
Execution time: 0.23 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:39 PM
