Username Post: Powerglide leaking after setting awhile        (Topic#345379)
555657
Loc: Belmont, Ohio
Reg: 05-11-02
06-12-17 10:00 AM - Post#2695655
My Powerglide starts leaking about a pint of transmission fluid after setting for a few weeks.
If I run the car often it does not leak. I think it is the converter filling up then draining after setting. The car sets for months at a time.
Any fixes for this problem other than run the car more often?
steve65
steve65
Loc: new westminster bc
Reg: 09-25-13
06-12-17 09:23 PM - Post#2695742
    In response to 555657
Okay, nobody's said it yet so I will..."if a power glide is leaking it means there is still fluid in it".
But seriously, can you see where it's leaking from? The pan gasket, the fill tube(bad o-ring), the in/out lines or is it coming from the front pump seal?
What is the fluid level when it's warmed up, level ground, in park?
Knowing where it's coming from will help determine what's going on.
Steve65
Steve Duncan
65 Impala SS Convertible
Ermine White/ Black Top
357 4 spd auto
www.picturetrail.com/steved65
nstlga
nstlga
Loc: Colorado
Reg: 12-01-05
06-13-17 08:00 AM - Post#2695784
    In response to steve65
No pan on these power glides. Common problem often discussed on here. I make it a point to drive my car at least once a month even in the winter when I catch a nice day. Have never had to deal with it. Some have suggested on here to run it a pint low and it won't do it either. My friend got tired of his doing it; he broke down and put in a turbo 350.
He who dies with the most toys doesn't necessarily win, but had more fun getting to the finish line.
555657
Loc: Belmont, Ohio
Reg: 05-11-02
06-13-17 08:12 AM - Post#2695789
I have not looked to see were it was leaking from.
I just know I have a puddle on the floor before I start it up. I will look to see were it is coming from. The transmission was rebuilt when the car was restored, but that was 13 years ago. The car is seldom run. I have put 85 miles on the car in 13 years.
nstlga
nstlga
Loc: Colorado
Reg: 12-01-05
06-13-17 08:33 AM - Post#2695794
I think your first observation is correct. Quite frankly, with the infrequent use on your car, I'm surprised you don't have other such issues as well. What exactly is your car?
back2chevy
back2chevy
Loc: Burlington
Reg: 10-31-15
06-13-17 06:32 PM - Post#2695847
    In response to nstlga
My powerglide was leaking like that and it was the shifter shaft seal.
63 Impala 283
92 VR-4
555657
Loc: Belmont, Ohio
Reg: 05-11-02
06-14-17 11:27 AM - Post#2695923
1956 Chevy convertible
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
06-15-17 10:14 AM - Post#2696022
You need to put the top down and get out and drive it. Or loan it to me and I will drive it for you.
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
06-16-17 07:54 PM - Post#2696195
    In response to Rustchips
Keep the fluid level as low as possible. At the add line when hot and below the add line when when cold.
john_johnson
Loc: Chattanooga, TN
Reg: 08-31-07
07-06-17 08:55 AM - Post#2698949
Is it a Cast Iron Powerglide? On this forum, 10 years ago, there was plenty of discussion of the 'Powerglide belch' up through the filler tube if they are left sitting for awhile. Mine does it too. The explanation (prolly can still find it in here somewheres) that I believed at the time was - that the torque converter, when sitting for a long period of time, gives up a pulse of Transmission Fluid and in the big pulse that happens some of it comes up the tube and ends up a puddle on the floor. That happens with mine, that's been sitting for 10 years as i SLOWLY restored it. I've been moving it around alot this year - - cuz Im almost done with it - and does not do this puddle anymore.
"That's all I have to say about that!"
555657
Loc: Belmont, Ohio
Reg: 05-11-02
07-06-17 10:23 AM - Post#2698955
    In response to john_johnson
Yes, original cast iron Powerglide. It has belched up thru the tube in the past when you first start it. I am leaving the fluid low for now and starting it about once a month.
Execution time: 0.732 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:53 AM
