Username Post: 88 k1500 350 odd firing motor        (Topic#345233)
14fjr1300es
Reg: 06-05-17
06-05-17 05:05 PM - Post#2694570
I recently bought this truck and trying to figure out whats up with the odd firing it is doing. First I don't know if it is a 350 or if its original or from a junk yard or what? How do I find out what motor I have? Truck has 150k miles. It does run ok but just doesn't feel right and when I pulled the plugs that told me something is wrong. But here is what it is doing - cylinders 1, 4, 6 & 7 fire white hot. cylinders 2, 3, 5 & 8 burn cold. So I installed new plugs. I need to pull them and check to see what the new plugs tell me? Then I installed a new distributor and it made NO difference. Any ideas?
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
06-08-17 01:35 PM - Post#2695116
    In response to 14fjr1300es
If you draw a diagram of the cylinder layout and then mark the "cold" and "hot" cylinders, you can clearly see a pattern that looks like the fuel distribution of a dual plane intake manifold (which a stock manifold is).
1-7-4-6 are the outside cylinders on one bank; the inside cylinders on the opposite bank.
2-8-3-5 share the same pattern, just inside/outside on each bank are reversed.
I suspect the engine is a TBI induction (?). My guess is that one of the TBI injectors is either spraying too much or too little fuel.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 06-08-17 01:36 PM. Reason for edit: No reason given.
Execution time: 0.434 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:45 PM
