Username Post: Anyone do an LS 460LE swap in 42-46        (Topic#345098)
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
05-31-17 07:51 AM - Post#2693663
Thinking about doing a drive train upgrade on my 46 business coupe.I am sure someone has done this , any problems with the floor pan or firewall. Not wanting to change the inside of the car if so i will go another way on the 46.
autorepairguy
Reg: 04-10-16
09-20-17 09:46 AM - Post#2708231
    In response to cbmkr56
I'm doing this swap,only to the mock-up stage as of yet.But I have no interference with the firewall and only a very small bump to the edge of the tunnel where the trans cooling lines exit the trans.If you are interested I can send you a few pics.Oops, I should have mentioned my project has a M2 front crossmember in it.It is a 48 Fleetline aerosedan.
Edited by autorepairguy on 09-20-17 11:01 AM. Reason for edit: No reason given.
Broo102
Broo102
Loc: RANCHO CUCAMONGA, CA.
Reg: 09-30-14
10-14-17 11:10 AM - Post#2710842
    In response to autorepairguy
I did a 350 swap on my convert. It was with a Mustang II front end, Camaro trans and rear end
Broo
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Execution time: 0.307 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:47 AM
