Username Post: 1993 C4 master cylinder        (Topic#345007)
GM4ME
Reg: 05-21-05
05-26-17 05:43 PM - Post#2693074
Figure this: I have 93 C4.BASE (not ZR1) My problem is there is rubber hose attached to the master cyl. reservoir on the left side that is broken. Where does this hose and fluid go? Attempted to get a replacement but none come with the hose fitting on left side. New ones are "blank". Anyone seen this before?
Edited by GM4ME on 05-26-17 05:44 PM. Reason for edit: No reason given.
TAT_2
"17th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
05-27-17 04:15 AM - Post#2693102
    In response to GM4ME
IM IN THE HOUSE NOW,GIVE ME SOME TIME & I'LL TAKE A LOOK ON MINE.
I DID A QUICK SEARCH A MINUTE BACK & FOUND THIS THO
http://www.partsgeek.com/gbproducts/MC/3224-07 2305...
JUST LOOKED,I HAVE THAT HOSE ON MINE,IT MAKES A LOOP UNDER THE CYLINDER TO THE PLASTIC RESIVOR.
THENS THERES A SENDER IN THE HOSE ATTACHED TO A PURPLE & BLACK WIRE.
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD F-150 SUPER CAB XLT 4X4
NEXT ?
Edited by TAT_2 on 05-27-17 04:34 AM. Reason for edit: No reason given.
GM4ME
Reg: 05-21-05
05-27-17 06:24 AM - Post#2693107
    In response to TAT_2
I have access to Snap-on Shop Key but, there is no diagram for hydraulics. I see some C4's don't have it. Thinking about adding a brass fitting to the side. It's obviously is on the "low" side of the fluid. Pretty cheesy set up but, it is 24 yrs old.
TAT_2
TAT_2
Reg: 10-29-00
05-27-17 11:01 AM - Post#2693135
YUP LOW
IF I WAS GONA REPLACE THE RUBBER HOSE I WOULD USE A QUALITY RUBBER HOSE DESIGNED FOR FUEL INJ.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Execution time: 0.299 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:54 PM
