Username Post: Transmission removal with two piece drive shaft        (Topic#344970)
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
05-24-17 07:29 PM - Post#2692787
I have been thinking about doing a torque converter change. The plan is to unbolt the the transmission from the motor and slide it back far enough to switch out the converter. The question is what is involved with the two piece drive shaft? Do I have to drop the carrier bearing or is there a way to remove the front shaft only? I hate crawling around on the floor. I am also planning on doing a rear gear change. I have a friend that owns an automotive shop that I plan on having him do the gears. Depending on what is involved with the transmission and drive shaft I might just pay him to do it all at the same time. I normally don't pay to have things done that I can do but I really don't like the garage floor especially when it's 110* outside.
71 Chevelle BBC powered
2010 GMC Sierra crew cab 4X4
05-24-17 10:24 PM - Post#2692800
    In response to LUVmachine
Does your trans output shaft have a slip yoke rather than a bolted yoke or flange? If yes, you will have to unbolt the rear U-joint and the center bearing and then pull the shaft out from the rear. If you are willing to pull an automatic transmission, then the center bearing is no big deal at all.
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
05-25-17 05:42 AM - Post#2692829
I'm not sure if the transmission has a slip yoke or not. The few times I have crawled under my truck my goal was to get in and out as fast as possible so I guess I never really paid attention to anything other than what I was doing at the time.
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
06-22-17 06:19 PM - Post#2697113
I ain't never done dat...but, I have changed the flex-plate the way you want to do.
When I did it, the shaft had to come out and I only pulled it back about 4".
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
07-18-17 04:25 PM - Post#2700532
    In response to Stinky
Taking the 2 piece shaft out is easy. Choke the wheels and put it in neutral on the rear end take the universal clips loose and let the drive shaft hang. Then take the carrier two bolts loose and slide it out of the truck.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
07-18-17 08:29 PM - Post#2700560
    In response to Andy4639
The truck magically turned into a Chevelle over night.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
07-19-17 08:18 AM - Post#2700595
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Execution time: 0.321 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:23 PM
