Username Post: Distributor ground wire...        (Topic#344859)
PeteVS
PeteVS
Loc: 07932
Reg: 01-28-17
05-21-17 06:04 PM - Post#2692171
Does anyone have a good picture of how the ground wire runs from the vacuum advance screw to the breaker plate on a "window" style 8 cylinder distributor? As I recall, it's supposed to loop up and then back down and the condenser wire is supposed to run under the loop. Thanks for any help.
PeteVS
PeteVS
Loc: 07932
Reg: 01-28-17
05-22-17 12:44 AM - Post#2692212
    In response to PeteVS
NEVER MIND! I found an old shop manual and it's the primary lead to the coil that the condenser lead passes under. It does that so the condenser lead doesn't get tangled up in the advance mechanism under the rotor.
x inFEKTid x
x inFEKTid x
Loc: east side of atl
Reg: 04-14-08
06-11-17 05:01 PM - Post#2695525
Glad that you replied with the answers . Most just say I found it and leave it at that .. glad ya found it .
Edited by x inFEKTid x on 06-11-17 05:02 PM. Reason for edit: No reason given.
Execution time: 0.257 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:32 PM
