Username Post: MSD Issues        (Topic#344841)
Loc: Sanford NC
Reg: 08-27-03
05-20-17 02:12 PM - Post#2692057
Anybody have had issues with MSD 6AL boxes and MSD coils. A friend has gone through 2 coils already. Any information will be greatly appreciated. Thanks.
05-20-17 03:03 PM - Post#2692063
    In response to carolinakid
MSD coils have been an issue in the past. I am not up on what the best coil to use is right now - maybe a search in the performance subforum would give you an answer that will help.
This is not an issue of the box causing the coil to go bad, it's the coils themselves.
Loc: Addison, IL
Reg: 05-28-10
05-22-17 04:38 AM - Post#2692224
    In response to Rick_L
Big gaps are tough on coils. I run a rare metal tip plug at .35 and have not had issues. Or go to the HEI cap conversion and use a remote oil filled coil.
Loc: Orlando, FL .
Reg: 05-11-01
05-31-17 03:28 PM - Post#2693722
Hi Kid.
I have been running an MSD billet distributor and a MSD Blaster 2 coil in my 56 since 1998. In 2012 I added the MSD 6AL box. I have not had any problems at all. I sure love the 6AL box. Wow what a difference. I used to foul plugs if I wasn't careful starting the engine, but not now. It runs so much smoother now.
I am running it on a 383 stroker with dual quads and all roller.
hope that helps.
Keith Marang
Central Oklahoma Classic Chevy Club
Loc: Noble, Ok.
Reg: 12-08-05
06-16-17 12:25 PM - Post#2696159
    In response to 1956chevy
I run an MSD Digital 6 box and MSD HVC-2 coil, no issues here.
11.22 @ 117 N/A.
Phil's '55
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
06-19-17 04:18 AM - Post#2696487
Perhaps a continuity test or a ground test will help provide an answer.
I've found a few coil problems for friends in the past by discovering a ground fault at some point that had been overlooked.
Or maybe as remedial as it sounds, the coil was possibly sitting directly ON the hot intake manifold? They need an air gap. my .02
498 chevy
498 chevy
Loc: hayward ca.
Reg: 09-28-07
07-18-17 05:48 PM - Post#2700534
    In response to 4dr 57
that's a good thought about grounding. MSD need a very good ground. If a problem seems to come and go it sounds like a grounding fault problem. Ask me how I know this!!
Execution time: 0.21 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:52 AM
