Username Post: 56 Fuel Line Question        (Topic#344809)
jkinz99
Loc: Hamlin, NY
Reg: 08-23-02
05-19-17 04:28 AM - Post#2691856
I'm installing a new fuel line in my car. Complete with new sending unit. I have what may be a dumb question; Which end of the hard line does the short rubber line mount on? Or do I even need this part? the hard line could screw directly to the sending unit. Everything was already removed from my car when I got it, so I have no reference of what went where, and I can't find any good reference pic's on line.
1956 150 Sedan
1966 Impala Convertible
2005 Harley Fat Boy
chevyman57B.C.
Reg: 08-29-12
05-19-17 08:19 AM - Post#2691888
    In response to jkinz99
Your gas line that would go to the sending unit has a long bend curve to it and the other end has a small curve and is straight
The sending unit should recieve the bigger fitting where as the other end has a smaller fitting.
Larry
jkinz99
Loc: Hamlin, NY
Reg: 08-23-02
05-19-17 12:06 PM - Post#2691912
    In response to chevyman57B.C.
I figured it out. The short rubber fuel line goes between the fuel pump & hard fuel line. Not sure why, but that's where it's supposed to go.
1956 150 Sedan
2005 Harley Fat Boy
chevyman57B.C.
Reg: 08-29-12
05-19-17 04:55 PM - Post#2691942
the short rubber line next to the fuel pump, allows to move freely if you have any movement from the engine. and they do move.
If it was solid the steel line would break because
it would be stiff and the line would crack spilling gas out and your car would catch on fire
Larry
Edited by chevyman57B.C. on 05-19-17 04:57 PM. Reason for edit: No reason given.
jkinz99
Loc: Hamlin, NY
Reg: 08-23-02
05-19-17 05:30 PM - Post#2691946
Thanks Larry, that makes perfect sense. Now my only problem is I'm going to have to change my fuel pump to one that has the threaded port for that tube. The one that on it had the kind of port that a rubber line gets pushed onto & clamped.
1956 150 Sedan
2005 Harley Fat Boy
05-19-17 10:19 PM - Post#2691990
How about a hose barb to screw into the threaded port?
chevyman57B.C.
Reg: 08-29-12
05-20-17 06:09 AM - Post#2692014
If you have the correct fuel pump, the rubber flex line would screw in to fuel pump and the other end would screw into each other.
Larry
Execution time: 0.264 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:00 PM
